Question about the LED tutorial here
by tbrantb on Fri Mar 22, 2013 9:45 pm
I have a question about the last couple questions in the Adjusting brightness section of the "All about LEDs" tutorial
"How much current is flowing through the LED if when the pot is turned down? The forward voltage of the LEDs are 2.2V."
The tuturial says the answer is:
2.2V / 100 ohm = 22 milliamps.
Shouldn't the answer be:
(5V - 2.2V) / 100 ohm = 28 milliamps ???
tbrantb
Re: Question about the LED tutorial here
by adafruit_support_mike on Sat Mar 23, 2013 12:47 am
Yep.. good catch.
In Tyler's defense, I make that same mistake All. The. Time. ;-)
cron
