RGB LED pin assignments
by indy on Sat Mar 23, 2013 9:02 pm
I recently purchased a bunch of RGB LEDs (#302) and am finding something odd. The data sheet linked from the product page (BL-L515RGBW-CA) has the pins defined as such:
--Flat Side--
Pin 4: Red
Pin 3: Anode/Cathode
Pin 2: Blue
Pin 1: Green
That is what I was wanting (expecting), I am swapping these in on a PCB that previously used another brand with the same pin assignments.
But when I test/use the ones from Adafruit I am seeing the Blue and Green swapped:
--Flat Side--
Pin 4: Red
Pin 2: Green
Pin 1: Blue
Has anyone else seen this?
indy
Re: RGB LED pin assignments
by adafruit_support_bill on Sun Mar 24, 2013 7:17 am
It is possible out supplier sourced these from a different manufacturer. I'll look into it.
by indy on Sun Mar 24, 2013 10:40 am
Thank you for looking into it.
If I"m looking at it correctly it appears the RGB LED in Adafruit's Eagle library matches the swapped order - so I'm beginning to think that this might be a case of having the wrong datasheet.
indy
by adafruit on Mon Mar 25, 2013 11:21 am
Oops yes it was the wrong datasheet, updated now, please check the product page!
by DLG on Thu Oct 31, 2013 7:09 pm
I am runningg into the same problem originally reported by Indy. The green and blue pins ae reversed. Pin 1 is defined as green but is blue, pin 2 is defined as blue but is green.
Are you always sing the same supplier? When I go the BetLux website, their data sheet for the swame part number has a completely different pin arrangement. I need a reliable, constant pin out for installation into my system.
DLG
by adafruit on Fri Nov 01, 2013 2:42 pm
Right now we are using another supplier as our previous suppliers had a lot of lead time problems. I'll try to get a datasheet updated in the next couple days, all the LEDs in a pack are the same as they are pre-packed
