Connection of LPD8806 to BeagleBone Black
cookegmp
Post by cookegmp »
Sorry for the silly question. Which pin should I use to connect LPD8806 strips to a BeagleBone Black. In all of the examples included with Python LPD8806 libraries I can not find a pin for data and clock. Thanks for your help and sorry again for the silly question.
-James
adafruit_support_rick
Re: Connection of LPD8806 to BeagleBone Black
Post by adafruit_support_rick »
Which python code are you looking at? Adafruit_LEDPixels.py assigns CLK to pin 18 and DATA to pin 17
cookegmp
Post by cookegmp »
A ha! I was using the Extended LPD8806 for Pi library.
I need to attach multiple strips and I don't really require SPI. Can I add additional clock and data pins for the extra strips?
Sure. Adafruit_LEDpixels.py is actually written to use hardware SPI, but it includes a function called slowspiwrite (which it doesn't use). You can use that function and assign however many pairs of clock and data pins you like.
paxman81
Post by paxman81 »
I've been working with Adafruit_LEDPixels.py to run the WS2801 LED Pixels using a Beaglebone Black. SPI isn't really necessary (I also can't get SPI working properly either)
I'd like to use the slowspiwrite() function, but I'm just not sure how to use it. Specifically I"m not sure how the byteout parameter should be used.
I modified writestrip from:
def writestrip(pixels):
    spidev = file("/dev/spidev0.0", "w")
    for i in range(len(pixels)):
        spidev.write(chr((pixels[i]>>16) & 0xFF))
        spidev.write(chr((pixels[i]>>8) & 0xFF))
        spidev.write(chr(pixels[i] & 0xFF))
    spidev.close()
    time.sleep(0.002)
to
        slowspiwrite("P8_10","P8_12",(pixels[i]>>16) & 0xFF)
        slowspiwrite("P8_10","P8_12",(pixels[i]>>8) & 0xFF)
        slowspiwrite("P8_10","P8_12",pixels[i] & 0xFF)
    time.sleep(0.002)
Which causes some pretty erratic behavior with the LEDs. A few other attempts were with some other code got me a little close, but I've only been able to control the 1st LED in a string of 15.
Any help is greatly appreciated.
The byteout parameter should be identical to the argument in the spidev call:
        slowspiwrite("P8_10","P8_12", chr((pixels[i]>>16) & 0xFF))
        slowspiwrite("P8_10","P8_12", chr((pixels[i]>>8) & 0xFF))
        slowspiwrite("P8_10","P8_12", chr(pixels[i] & 0xFF))
paxman81
Post by paxman81 »
Thanks. I tried that in my original attempt, but received an error in the slowspiwrite function line
 if (byteout & 0x80):
The error was something to the effect of "Cannot combine types str and int." Which is why I removed chr() from the slowspiwrite call. I guess I'm not understanding why chr() has to be used. My full code is below in case my mistake is obvious to anyone else.
#!/usr/bin/env python
# Test code for Adafruit LED Pixels, uses hardware SPI
import ADAFRUIT_BBIO.GPIO as GPIO, time, os
def slowspiwrite(clockpin, datapin, byteout):
	GPIO.setup(clockpin, GPIO.OUT)
	GPIO.setup(datapin, GPIO.OUT)
	for i in range(8):
			GPIO.output(datapin, True)
		else:
			GPIO.output(clockpin, False)
		byteout <<= 1
		GPIO.output(clockpin, True)
ledpixels = [0] * 10
	spidev.close()
	time.sleep(0.002)
def Color(r, g, b):
	return ((r & 0xFF) << 16) | ((g & 0xFF) << 8) | (b & 0xFF)
def setpixelcolor(pixels, n, r, g, b):
	if (n >= len(pixels)):
		return
	pixels[n] = Color(r,g,b)
def setpixelcolor(pixels, n, c):
		return
	pixels[n] = c
def colorwipe(pixels, c, delay):
		setpixelcolor(pixels, i, c)
		writestrip(pixels)
		time.sleep(delay)
colorwipe(ledpixels, Color(255, 0, 0), 0.05)
colorwipe(ledpixels, Color(0, 255, 0), 0.05)
colorwipe(ledpixels, Color(0, 0, 255), 0.05)
I don't know much about python, but I imagine that the chr() was there to make sure that byteout was really just a byte. If you leave it an int, it will probably be 32 bits.
That said, the bit-shifting algorithm will still work, even with a 32-bit argument.
The BBB is faster than the Pi. I'm going to guess that the pulse width on the clockpin is too short. Try adding a 1 microsecond delay:
      <add a 1us delay here. If I knew python better, maybe I could tell you how to do that.>
