Since there are no tutorials for the NeoPixel Strip's And I'm Finally getting the hang of coding it.....I thought I'd share this Example I made of a Scrolling Cylon Eye!!!
Video: http://www.youtube.com/watch?v=UW2_cEKGV68
Things you will need:
1. 1x Strip of the NeoPixel: http://www.adafruit.com/products/1376 (or you can use the NeoPixel Stick/Bar -> http://www.adafruit.com/products/1426 )
2. 1x Arduino(I have the Arduino Uno[ATMEGA328P-PU]): http://www.adafruit.com/products/50
3. The Arduino Programming Software: http://arduino.cc/en/Main/Software
4. The Library from here: https://github.com/adafruit/Adafruit_NeoPixel
And Finally Here's the Code: https://github.com/EternalCore/NeoPixel ... olling_Eye
Changes:
v1.10 - Added NeoPixel Bar/Stick option.
Other Helpful Threads I created:
[101-Help]~12v -> 5v 1.5A Regulated PowerCircuit For NeoPixels.
[101-Help]~12v -> 5v 3A Parallel Regulated PowerCircuit For NeoPixels.
Hope you enjoy it As I May make more examples.
[Example]NeoPixel Strip Scrolling Cylon Eye! NOW WITH VIDEO!!!
Re: [Example]NeoPixel Strip Scrolling Cylon Eye!
Cool Thanks for posting!
You're Welcome. And you are welcome to add this to your examples in your Library files.adafruit_support_bill wrote:Cool Thanks for posting!
Updated to v1.02: Fixed to use the whole strip of 60 leds again.
Updated to v1.03: Minor Setting fixes to speed up the performance.
UPDATE: Added Video -> http://www.youtube.com/watch?v=UW2_cEKGV68
- ohararp
Re: [Example]NeoPixel Strip Scrolling Cylon Eye! NOW WITH VIDEO!!!
Eternalcore, I had been meaning to code up a similar cylon scanner code for a simple 1x8 matrix for sometime. Thanks for sharing/posting! I was able to include your code in my kickstarter video at the 3:23 mark of the video http://kck.st/1cyHkAj.
Nice!ohararp wrote:Eternalcore, I had been meaning to code up a similar cylon scanner code for a simple 1x8 matrix for sometime. Thanks for sharing/posting! I was able to include your code in my kickstarter video at the 3:23 mark of the video http://kck.st/1cyHkAj.
For the 1x8 bar you can just comment out these lines so it only uses 3leds:
For Scan Up:
//strip.setPixelColor(i+2, Ctt); //Third Dot Color
strip.setPixelColor(i+1, Ct); //Second Dot Color
strip.setPixelColor(i, Co); //Center Dot Color
strip.setPixelColor(i-1, Ct); //Second Dot Color
//strip.setPixelColor(i-2, Ctt); //Third Dot Color
//And change this line below to this
strip.setPixelColor(i-2, strip.Color(0,0,0)); //Clears the dots after the 3rd color
strip.setPixelColor(i+2, strip.Color(0,0,0)); //Clears the dots after the 3rd color
This is practically exactly what I need for my PAX project! Thanks for forcing me to read annotations in arduino.
I was wondering, is there a way to control how fast the eye scrolls?
Yes by Changing the number on this line in the code:gozeeta wrote:This is practically exactly what I need for my PAX project! Thanks for forcing me to read annotations in arduino.
int wait_T=40; //This is the delay between moving back and forth and per pixel
Awesome! Thanks! Playing around, I'm trying to make the eye go only one way, have a shorter overall width (3 LED instead of 5), and waiting a couple seconds between each "pulse." Here's what I have so far:
But now that I've removed the scroll down, the last two pixels at the end never turn off! I wonder what I did wrong...
//Example: CylonEyeUp(Center_Dot_Color, Second_Dot_color, Third_Dot_color, wait_T, PixelCount, Pixel_Start_End);
CylonEyeUp(strip.Color(250,161,0), strip.Color(255,143,0), wait_T, PixelCount, Pixel_Start_End);
delay(wait_T);
strip.show();
//Example: CylonEyeDown(Center_Dot_Color, Second_Dot_color, Third_Dot_color, wait_T, PixelCount, Pixel_Start_End);
delay(2000);
void CylonEyeUp(uint32_t Co, uint32_t Ct, uint8_t Delay, int TotalPixels, int pStart) {
for(int i=pStart; i<TotalPixels; i++) {
strip.show();
//Serial.println(i); //Used For pixel Count Debugging
delay(Delay);
Here you go I added a new script just for you, for what you are trying to do: https://github.com/EternalCore/NeoPixel ... OneWay.inogozeeta wrote:Awesome! Thanks! Playing around, I'm trying to make the eye go only one way, have a shorter overall width (3 LED instead of 5), and waiting a couple seconds between each "pulse." Here's what I have so far:
But now that I've removed the scroll down, the last two pixels at the end never turn off! I wonder what I did wrong...Code: Select all
-snip-
To change the timing of between pulses change the number in int 'refresh', to change the speed of it scrolling change the number in int 'wait_T' and 1000 is equal to 1second.
-Enjoy
- mordecai131
Hey EternalCore, I saw in your first post that your code would need some tweaking to work with the NeoPixel sticks. What things need to be tweaked to get the stick to work? I have tried the sample test code that Adafruit provided and wasn't able to figure it out either. Any help is greatly appreciated. Thanks.
I've been busy so I haven't had time to update this script, but I have time now so give me a few to add it and I'll post an update here. Just keep refreshing until you see my next post.mordecai131 wrote:Hey EternalCore, I saw in your first post that your code would need some tweaking to work with the NeoPixel sticks. What things need to be tweaked to get the stick to work? I have tried the sample test code that Adafruit provided and wasn't able to figure it out either. Any help is greatly appreciated. Thanks.
UPDATED: v1.10 - Added option for the NeoPixel Bar/Stick to change the size of the scanner leds between 5(for Strip) and 3(for Bar/Stick).
- mordecai131
Thank you for going through all that, unfortunately it's not working for me for some reason. I believe I used the code properly but I have a feeling it may be the type of board I'm using, chipKit uC32. After some experimenting I found that if I run 12 volts through the AC plug on the board and bypass the 5 volt regulator I can get the sticks to flash a pinkish color. But it does not respond to the code, even if I unplug the signal wire, reset the board, and even upload new code to the board which normally resets it as well the sticks continue to blink.
