I have Arduino installed and running with all the Adafruit extras and the Gemma blink test worked as expected.
However, now when I upload the strandtest, all I get is one LED on the NeoPixel ring constantly lit at what seems to be maximum pinkish white(?) brightness. Looking at the back (non LED side) of the NeoPixel ring, the one LED that lights up is the one directly clockwise from the Data Out connection.
Strandtest:
#define PIN 6
// Parameter 1 = number of pixels in strip
// Parameter 2 = pin number (most are valid)
// Parameter 3 = pixel type flags, add together as needed:
// NEO_KHZ800 800 KHz bitstream (most NeoPixel products w/WS2812 LEDs)
// NEO_KHZ400 400 KHz (classic 'v1' (not v2) FLORA pixels, WS2811 drivers)
// NEO_GRB Pixels are wired for GRB bitstream (most NeoPixel products)
// NEO_RGB Pixels are wired for RGB bitstream (v1 FLORA pixels, not v2)
Adafruit_NeoPixel strip = Adafruit_NeoPixel(60, PIN, NEO_GRB + NEO_KHZ800);
strip.begin();
strip.show(); // Initialize all pixels to 'off'
// Some example procedures showing how to display to the pixels:
colorWipe(strip.Color(255, 0, 0), 50); // Red
colorWipe(strip.Color(0, 255, 0), 50); // Green
colorWipe(strip.Color(0, 0, 255), 50); // Blue
rainbow(20);
rainbowCycle(20);
// Fill the dots one after the other with a color
void colorWipe(uint32_t c, uint8_t wait) {
for(uint16_t i=0; i<strip.numPixels(); i++) {
strip.setPixelColor(i, c);
strip.show();
delay(wait);
void rainbow(uint8_t wait) {
uint16_t i, j;
for(j=0; j<256; j++) {
for(i=0; i<strip.numPixels(); i++) {
strip.setPixelColor(i, Wheel((i+j) & 255));
strip.show();
delay(wait);
// Slightly different, this makes the rainbow equally distributed throughout
void rainbowCycle(uint8_t wait) {
uint16_t i, j;
for(j=0; j<256*5; j++) { // 5 cycles of all colors on wheel
for(i=0; i< strip.numPixels(); i++) {
strip.setPixelColor(i, Wheel(((i * 256 / strip.numPixels()) + j) & 255));
strip.show();
delay(wait);
// Input a value 0 to 255 to get a color value.
// The colours are a transition r - g - b - back to r.
uint32_t Wheel(byte WheelPos) {
if(WheelPos < 85) {
return strip.Color(WheelPos * 3, 255 - WheelPos * 3, 0);
} else if(WheelPos < 170) {
WheelPos -= 85;
return strip.Color(255 - WheelPos * 3, 0, WheelPos * 3);
} else {
WheelPos -= 170;
return strip.Color(0, WheelPos * 3, 255 - WheelPos * 3);
Powerplant code:
//Superhero Power Plant
//fades all pixels subtly
//code by Tony Sherwood for Adafruit Industries
#define PIN 1
Adafruit_NeoPixel strip = Adafruit_NeoPixel(17, PIN, NEO_GRB + NEO_KHZ800);
int alpha; // Current value of the pixels
int dir = 1; // Direction of the pixels... 1 = getting brighter, 0 = getting dimmer
int flip; // Randomly flip the direction every once in a while
int minAlpha = 25; // Min value of brightness
int maxAlpha = 100; // Max value of brightness
int alphaDelta = 5; // Delta of brightness between times through the loop
strip.begin();
flip = random(32);
if(flip > 20) {
dir = 1 - dir;
if (dir == 1) {
alpha += alphaDelta;
if (dir == 0) {
alpha -= alphaDelta;
if (alpha < minAlpha) {
alpha = minAlpha;
dir = 1;
if (alpha > maxAlpha) {
alpha = maxAlpha;
dir = 0;
// Change the line below to alter the color of the lights
// The numbers represent the Red, Green, and Blue values
// of the lights, as a value between 0(off) and 1(max brightness)
// EX:
// colorWipe(strip.Color(alpha, 0, alpha/2)); // Pink
colorWipe(strip.Color(0, 0, alpha)); // Blue
void colorWipe(uint32_t c) {
strip.show();
Can anybody help by tonight? Please?
