Now with 24bit support and 30hz framerate, using a Teensy! I believe this is a first. To achieve this, I prepare the interleaved, gamma-corrected buffer on the PC and stream it live. I don't use DMA yet, this could reduce CPU even more.
Especially on dark scenes there are still some artifacts on the bottom side, must either be a bug or timing issue.
* Modified by Markus Lipp adding interleaved buffers, streaming, 32x32 & 24bit support
* Based on "_16x32_Matrix R3.0" by Creater Alex Medeiros, http://PenguinTech.tk
* Use code freely and distort its contents as much as you want, just remeber to thank the
* original creaters of the code by leaving their information in the header. :)
//PortC[0:11] = {15, 22, 23, 9, 10, 13, 11, 12, 28, 27, 29, 30}
//PortD[0:7] = {2, 14, 7, 8, 6, 20, 21, 5}
//Define pins
const uint8_t
//PortC
APIN = 15, BPIN = 22, CPIN = 23, DPIN = 9,
CLOCKPIN = 10, LATCHPIN = 13, OEPIN = 11,
//PortD
R1PIN = 2, R2PIN = 8,
G1PIN = 14, G2PIN = 6,
B1PIN = 7, B2PIN = 20;
uint8_t pinTable[13] = {
R1PIN,R2PIN,G1PIN,G2PIN,B1PIN,B2PIN,
APIN,BPIN,CPIN,DPIN,CLOCKPIN,LATCHPIN,OEPIN};
//Addresses 1/8 rows Through a decoder
uint16_t const A = 1, B = 2,C = 4, D=8;
//Acts like a 16 bit shift register
uint16_t const SCLK = 16;
uint16_t const LATCH = 32;
uint16_t const OE = 64;
uint16_t const abcVar[16] = { //Decoder counter var
0,A,B,A+B,C,C+A,C+B,A+B+C,
0+D,A+D,B+D,A+B+D,C+D,C+A+D,C+B+D,A+B+C+D};
//Data Lines for row 1 red and row 9 red, ect.
uint16_t const RED1 = 1, RED2 = 8;
uint16_t const GREEN1 = 2, GREEN2 = 16;
uint16_t const BLUE1 = 4, BLUE2 = 32;
const uint8_t SIZEX = 32;
const uint8_t SIZEY = 32;
//Here is where the data is all read
uint8_t interleavedBuffer[SIZEX*SIZEY*4];
//BAM and interrupt variables
boolean actDisplay = false;
uint8_t rowN = 0;
uint16_t BAM;
uint8_t BAMMAX = 7; //now 24bit color! (0-7)
for(uint8_t i = 0; i < 13; i++){
pinMode(pinTable[i], OUTPUT);
timerInit();
Serial.begin(250000);
uint8_t r,g, prevVal,val;
int dataPos=0;
if (Serial.available())
prevVal = val;
val = Serial.read();
if ( (prevVal==192 && val==192) || dataPos>=4096)
dataPos=0;
else
interleavedBuffer[dataPos++] = val;
IntervalTimer timer1;
#define BAMDUR 2
void timerInit() {
BAM = 0;
timer1.begin(attackMatrix,BAMDUR);
//Where the PIT calls
//The updating matrix stuff happens here
//each pair of rows is taken through its BAM cycle
//then the rowNumber is increased and id done again
void attackMatrix() {
uint16_t portData;
//sets up which BAM the matrix is on
if(BAM == 0) { timer1.begin(attackMatrix,BAMDUR); } //code takes max 41 microsec to complete
if(BAM == 1) { timer1.begin(attackMatrix,BAMDUR*2); } //so 42 is a safe number
if(BAM == 2) { timer1.begin(attackMatrix,BAMDUR*4); }
if(BAM == 3) { timer1.begin(attackMatrix,BAMDUR*8); }
if(BAM == 4) { timer1.begin(attackMatrix,BAMDUR*16); }
if(BAM == 5) { timer1.begin(attackMatrix,BAMDUR*32); }
if(BAM == 6) { timer1.begin(attackMatrix,BAMDUR*64); }
if(BAM == 7) { timer1.begin(attackMatrix,BAMDUR*128); }
portData = 0; // Clear data to enter
portData |= (abcVar[rowN])|OE; // abc, OE
portData &=~ LATCH; //LATCH LOW
GPIOC_PDOR = portData; // Write to Port
uint8_t *start = &interleavedBuffer[rowN*SIZEX*8+((7-BAMMAX)+BAM)*32];
for(uint8_t _x = 0; _x < 32; _x++){
GPIOD_PDOR = start[_x]; // Transfer data
GPIOC_PDOR |= SCLK;// Clock HIGH
GPIOC_PDOR &=~ SCLK;// Clock LOW
GPIOC_PDOR |= LATCH;// Latch HIGH
GPIOC_PDOR &=~ OE;// OE LOW, Displays line
if(BAM >= BAMMAX) { //Checks the BAM cycle for next time.
if(rowN == 15){
rowN = 0;
} else {
rowN ++;
BAM = 0;
actDisplay = false;
} else {
BAM ++;
actDisplay = true;
