When I first used my shield touch worked fine. However since then I have been unable to get it
to work again.
I have checked the continuity of all pins from my pi through the shield to a cobbler attached to the gpio socket on the shield, this all seems fine.
I have reinstall 2013-09-25 Raspbian, both with updates and without.
The tft screen works fine.
dmesg output:
[ 12.142553] bcm2708_spi bcm2708_spi.0: DMA channel 0 at address 0xf2007000 with irq 16
[ 12.154984] bcm2708_spi bcm2708_spi.0: DMA channel 4 at address 0xf2007400 with irq 20
[ 12.168756] spi_master spi0: will run message pump with realtime priority
[ 12.183314] bcm2708_spi bcm2708_spi.0: SPI Controller at 0x20204000 (irq 80)
[ 12.200178] bcm2708_spi bcm2708_spi.0: SPI Controller running in polling mode
[ 12.361965] fbtft_device: SPI devices registered:
[ 12.368259] fbtft_device: spidev spi0.0 500kHz 8 bits mode=0x00
[ 12.391886] fbtft_device: spidev spi0.1 500kHz 8 bits mode=0x00
[ 12.399710] fbtft_device: 'fb' Platform devices registered:
[ 12.406829] fbtft_device: bcm2708_fb id=-1 pdata? no
[ 12.413675] fbtft_device: Deleting spi0.1 (spi0.1)
[ 12.422455] fbtft_device: Looking at item 0
[ 12.428043] fbtft_device: Setting pin 24 to 2
[ 12.520477] stmpe-spi spi0.1: unknown chip id: 0x0
[ 12.526654] stmpe-spi: probe of spi0.1 failed with error -22
[ 12.539590] fbtft_device: Deleting spi0.0 (spi0.0)
[ 12.548712] fbtft_device: GPIOS used by 'adafruitts':
[ 12.570182] fbtft_device: 'dc' = GPIO25
[ 12.575610] fbtft_device: SPI devices registered:
[ 12.587024] fbtft_device: stmpe610 spi0.1 500kHz 8 bits mode=0x00
[ 12.605285] fbtft_device: fb_ili9340 spi0.0 32000kHz 8 bits mode=0x00
[ 12.983767] graphics fb1: fb_ili9340 frame buffer, 320x240, 150 KiB video memory, 16 KiB buffer memory, fps=20, spi0.0 at 32 MHz
Is there anything else to try or is it a duff chip?
Thanks.
Rod
PiTFT Still getting unknown chip error
Re: PiTFT Still getting unknown chip error
The "failed with errno -22" thing is normal. The OS checks a signal the TFT driver doesn't support before going on to the rest of the initialization.
This line:
says the RasPi is talking to the TFT driver, and the fact that it goes on to configure a framebuffer means things look good on the software side.
Have you double-checked the flex cable between the TFT and the PCB? It can come partway loose and interfere with the signals, but still looks okay when that happens.
This line:
- rnorfor
Thanks for the reply,
The flex cable seems to be connected.
I have removed and reconnected it.
Still can't get the touchscreen detected.
Is there anything else I can check as to why the touchscreen isn't detected?
Could it be a software rather than hardware issue?
Rod
Rod
If the cable is good, that sounds more like a hardware problem than a software problem.
Let's try a new one: send a note to [email protected] with a link to this thread and the folks there will get you a replacement.
- ehanoc
Im having the exact same problem. My screen works but no touch events are detected. The dmesg log is very similar to mine. Help ...
- Franklin97355
Please post your dmesg log.
- ehanoc
[ 12.119781] fbtft_device: SPI devices registered:franklin97355 wrote:Please post your dmesg log.
[ 12.128620] fbtft_device: spidev spi0.0 500kHz 8 bits mode=0x00
[ 12.136733] fbtft_device: spidev spi0.1 500kHz 8 bits mode=0x00
[ 12.150564] fbtft_device: 'fb' Platform devices registered:
[ 12.157847] fbtft_device: bcm2708_fb id=-1 pdata? no
[ 12.176134] fbtft_device: I2C devices registered:
[ 12.182664] fbtft_device: i2c-0 addr 48896 IRQ 0
[ 12.189459] fbtft_device: i2c-1 addr 48896 IRQ 1
[ 12.196318] fbtft_device: pcm5122 1-004d addr 77 IRQ 0
[ 12.203637] fbtft_device: wm8804 1-003b addr 59 IRQ 0
[ 12.210831] fbtft_device: pcm5122 1-004c addr 76 IRQ 0
[ 12.290444] fbtft_device: Deleting spi0.1 (spi0.1)
[ 12.303250] stmpe-spi spi0.1: unknown chip id: 0x0
[ 12.315748] stmpe-spi: probe of spi0.1 failed with error -22
[ 12.330725] fbtft_device: Deleting spi0.0 (spi0.0)
[ 12.344274] fbtft_device: GPIOS used by 'adafruitrt28':
[ 12.359339] fbtft_device: 'dc' = GPIO25
[ 12.370566] fbtft_device: SPI devices registered:
[ 12.376836] fbtft_device: stmpe610 spi0.1 500kHz 8 bits mode=0x00
[ 12.400594] fbtft_device: fb_ili9340 spi0.0 32000kHz 8 bits mode=0x00
[ 12.683839] i2c /dev entries driver
[ 13.006727] graphics fb1: fb_ili9340 frame buffer, 320x240, 150 KiB video memory, 4 KiB DMA buffer memory, fps=20, spi0.0 at 32 MHz
[ 18.667837] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 21.536269] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 30.465484] Adding 102396k swap on /var/swap. Priority:-1 extents:1 across:102396k SSFS
My dmesg log. Thanks for the quick reply
