Hi
I have a few questions regarding the USB + Serial Backpack Kits (ID782/789).
1) Is it possible to buy the USB backplane with a 20X4 display instead of the 16x2 one shown?
2) Has it been tested for compatibility with LCDProc on FreeBSD 9.2.X? I am wanting this as an information display on a NAS box I am building.
3) Will the backplane work with a Raspberry Pi? I have a project in mind that will use the 71mm touchscreen LCD and, if possible, a seperate LCD display that does not tie up the GPIO pins. I need the pins as part of the project.
USB + Serial Backpack Kit questions
- adafruit_support_rick
Re: USB + Serial Backpack Kit questions
We don't stock the kit with a 20x4. You'd have to purchase that separatelyKiwiGeek wrote:1) Is it possible to buy the USB backplane with a 20X4 display instead of the 16x2 one shown?
I don't have any information on specific OS configurations. All I have is the general information that the USB interface shows up as a COM/serial port on Windows/Mac/Linux. If the USB doesn't work for some reason, you can always fall back to serial.KiwiGeek wrote:2) Has it been tested for compatibility with LCDProc on FreeBSD 9.2.X? I am wanting this as an information display on a NAS box I am building.
It should work either as serial or USB with the Pi.KiwiGeek wrote:3) Will the backplane work with a Raspberry Pi? I have a project in mind that will use the 71mm touchscreen LCD and, if possible, a seperate LCD display that does not tie up the GPIO pins. I need the pins as part of the project.
Is the firmware sourcecode for the AT90USB162 available for those wishing to tweak it or reprogram the backpack?
It's all linked in the Tutorial:
http://learn.adafruit.com/usb-plus-seri ... /downloads
