Panel resolution for Qualia Bare Driver Board
If I would like to use another LCD panel with Qualia Bare Driver Board, what is the highest monitor resolution this board can support? Can it drive 2560x1600 panel?
- adafruit_support_rick
Re: Panel resolution for Qualia Bare Driver Board
It will drive 2048x1536
Hi, I wonder if the Qualia Bare Driver Board can drive the 7.9-inch 2048-by-1536 resolution at 326 pixels per inch (ppi) of the new ipad mini retina?
Can't find the code for the 7.9 one (I know the ipad air 9.7 is LG LP097QX1)
No idea, we haven't seen a mini Retina screen - if you post up a source we can check it out!
Thanks for the reply.
The new ipad mini retina also features a 2048-by-1536 screen, but it's 7.9 inches at 326 ppi.
https://www.apple.com/ipad-mini/
http://www.ifixit.com/Teardown/iPad+Min ... down/19374
"Our little Retina has an LG display, powered by a Parade DP675 LCD driver, similar to the DP655 found in the iPad Air. Also present at the party, a TI TPS65143A and a pair of TI TPS65195, all likely LCD power supply ICs."
http://www.ebay.com/itm/New-Replacement ... 35d31df9b6 ??
If the Qualia can drive this 7.9 screen it means this year I can present my masters at Uni
I need to drive a less than 8 inches screen at the highest ppi possible...and if it's displayport, even better.
Thank you.
Thank you.
well, good news is its *probably* the same kind of driver. the really bad news is the connector is completely different! You'll need to figure out what it is, what the connector is, get a PCB made...its a lot of work
if you just need a high res display check out our 5.6" 1280x800 - its nearly retina DPI!
http://www.adafruit.com/products/1666
its by far the easiest way and the highest-DPI display we could easily drive
Thanks heaps for your reply.
the 720p one is not really useful as it's 3 times less amount of pixels.
I'll try to achieve the same thing with your kit display.
Cheers.
Cheers.
Thanks heaps for your courtesy.
One last question, do you think I could get someone to make a custom PCB for it? At least try to get it to run.
Do you know where I could ask for it? I have some budget available.
I'm doing a research for the university where I work and I need a 7ish inches screen with the highest resolution possible (hence why displayport is preferred).
Again, thanks for your time, you guys are great.
There are loads of places that will make you a custom PCB. The issue is getting someone to design it for you. There must be Electrical Engineering students at your university. I'd go talk to one of the professors and see if he can recommend somebody.
Hi! This driver compatible with LG LP173WF2? It FullHD screen with 50pin eDP connector
I have no idea. We only support the LG LP097QX1. We can't keep track of compatibility with every possible display.AAmk wrote:Hi! This driver compatible with LG LP173WF2? It FullHD screen with 50pin eDP connector
What kind of connector you have used for this driver?adafruit_support_rick wrote:I have no idea. We only support the LG LP097QX1. We can't keep track of compatibility with every possible display.AAmk wrote:Hi! This driver compatible with LG LP173WF2? It FullHD screen with 50pin eDP connector
p.s. sorry for my english)
- adafruit2
You can read more about how to design this yourself here
http://mikesmods.com/mm-wp/?page_id=11
Thanks! It very useful information
