Ring 24 GitHub board layout wrong?
davidl13
Post by davidl13 »
Hi all,
The Ring 24 board layout at GitHub (https://github.com/adafruit/Adafruit-NeoPixel-Ring) doesn't appear to match the board I received in a recent order. The physical board has 2 VCC and 2 GND connectors but the GitHub board layout shows only 1 each. Was there a layout revision that didn't make it to GitHub?
Re: Ring 24 GitHub board layout wrong?
Post by adafruit »
hi! yes we recently revised it to use the newer 'B type pixels, added an inline resistor to protect the DIN pin and added some VCC/GND pads. the LED locations are the same, and its otherwise a 'drop in' replacement - same code and size, etc.
davidl13
Post by davidl13 »
OK, all well and good but when will the updated files be available?
davidl13
Post by davidl13 »
More specifically, I need the coordinates of the 4 power and 2 data holes.
davidl13
Post by davidl13 »
Uh, hello?
