Arduino XBee and LED Lighting Question
mattjames
Post by mattjames »
So I posted in the General help forum about a project I was going to do and now I am at a road block. So here is my setup.
2x Arduino Uno R3 (We'll call them Arduino1 and Arduino2)
2x SainSmart XBee Shield
2x XBee Pro Series 1 60mw
2x 75mm Bars - 12V Digital RGB LED Pixels
As of right now I have Vixen3 lighting software on one computer through USB controlling one strand of the pixels on Pins 2 and 3 on Arduino1 with no problems. I am having trouble sending the data from Arduino1 to Arduino2 with the XBee to recreate what is happening on Arduino1 without having to use another computer. I have posted the code that I am using to control the LEDs on Arduino1, most of the code is borrowed. I really could use some help on this one because my head hurts from banging it against the wall.
#include "Adafruit_WS2801.h"
#include "SPI.h"
#define DPIN 2
#define CPIN 3
int   PixelCount = 21;
int   bugLevel  = 0;
Adafruit_WS2801 strip = Adafruit_WS2801(21, DPIN, CPIN);
void setup()
  delay(100);
  strip.begin();
  strip.show();
  Serial.begin(115200);
void loop()
	if (Serial.available()>2)
    waitForVixenHeader();
  	for (int pixCount=0; pixCount<PixelCount;pixCount++)
      int RGB[3];
      for (int color = 0;color<3;color++)
        while (Serial.available() < 1)
          delay(10);
        RGB[color] = Serial.read();
      strip.setPixelColor(pixCount,RGB[0],RGB[1],RGB[2]);
    strip.show();
void waitForVixenHeader()
    char *header="VIXStart";
    char buffer[3];
    int index = 0;
    while (true)
        int inByte = Serial.read();
        if(inByte==-1)
          continue;
        buffer[index] = inByte;
        if(buffer[index]!=header[index])
            index=-1;
        buffer[index+1] = 0;
        index++;
        if(index==8)
          return;
adafruit_support_rick
Re: Arduino XBee and LED Lighting Question
Post by adafruit_support_rick »
Please don't double post
