LED strips fry with Raspberry Pi
I am trying to follow this guide: https://learn.adafruit.com/raspberry-pi ... d-software . And my LED strip I just got is not responding to my raspberry pi and it also smelled like electrical burning initially. You can see where it got too hot and melted the plastic coating. I identified it as one of the black things in between LEDs ( I assume amps). I connected it to a 5V 800mA power supply. I checked to make sure that the CI and DI cables were not switched and also made sure it was connected to the input of the LED strip. These are the LEDs I am using. http://www.adafruit.com/products/306
- Attachments
- IMG_0349.jpg (418.73 KiB) Viewed 304 times
- IMG_0348.jpg (298.63 KiB) Viewed 304 times
- adafruit_support_rick
Re: LED strips fry with Raspberry Pi
Can you please post a picture showing how the adapter is connected to the strip? Are you sure you didn't reverse +5V and Ground?
White is the ground from the female dc adapter I got from adafruit as well. And from left to right (or bottom to top depending on which way it uploads) The JST is CI,+5,DI,GND. Its that order because the CI didn't wanna go in the breadboard so I just clamped it to a wire and it torks it out of the picture. You can kinda see that.
- Attachments
- IMG_0352.jpg (611.49 KiB) Viewed 268 times
You're back-powering the Pi through the ribbon cable?
No but that's how the tutorial said to wire it.
So it does. Hmm... not sure I like that. You should leave the ground - it's necessary. But I would disconnect the 5V from the Pi ribbon cable.camjones1708 wrote:No but that's how the tutorial said to wire it.
Meanwhile. Please email [email protected] with a link to this thread for a replacement LED strip.
I did that and also removed the led segment that smelled of electric burning. Now (skipping the first two) the led strip lights up two of every eight. For example:
x's are off and o's are on: xx oo xx xx xx xx oo xx xx xx xx oo xx xx xx. This is regardless of me running any code on my pi or not. I checked again to make sure the two inputs are not switched coming from the pi. And that the ground is connected to the raspberry pi as well.
Well, if you burned out one segment, the whole strip is suspect. Let's try the replacement and see.
