Loop gets stuck on the strip
I'm using 90 LEDs on a Neopixel strip and when running the sample test sketch, it gets stuck in the middle of the algorithm. Is this a RAM issue?
- pburgess
Re: Loop gets stuck on the strip
Depends. What board are you using? If Trinket, RAM's a possibility. If it's an Uno or something similar, it's usually several hundred pixels before this becomes a problem.
