RA8875 Driver Board for 40-pin TFT Touch Displays
garyvdg
Post by garyvdg »
Just received an RA8875 Driver Board and a 4.3" TFT Display and I have a few questions about wiring it up. I plan to use this with Arduino UNO or MEGA.
I am not clear about the backlighting wiring connection. On the back of the board it says, "Close 25 mA/100 mA jumpers for C.C". Do I have to (must I) use one or the other of these? Does it really need a separate (up to) 24V supply applied to the LITE pin (4th from left)?
Based on the Adafruit examples (e.g., buildtest), it looks like I would connect the board to an Arduino UNO as follows:
Pins 1 and 2, Vin and GND.
Pins 5, 6, 7 and 8 for SPI on UNO 13, 12, 11 and 10.
Pin 9 (RST) to UNO pin 9
Pin 11 (Int) to UNO Pin 3.
What about the Y+, Y-, X+ and X- pins? Do they connect to the UNO or are the X-Y positions on the touch pad read through the SPI software?
What is the WAIT pin for?
Lastly, do I connect the LITE pin to a voltage supply?
Thanks.
Don't need a full tutorial, but some additional info on the wiring for the board with Arduino UNO would be helpful.
adafruit_support_rick
Re: RA8875 Driver Board for 40-pin TFT Touch Displays
Post by adafruit_support_rick »
Leave the jumper open
Don't connect LITE to anything
Don't connect WAIT to anything
Don'y connect X+,X-,Y+,Y- The touch events come through SPI
local_dani_21
Post by local_dani_21 »
I just wired up my 5" 800x480 TFT using the RA8875 an it all (including bitmaps) works well. I have an alike question as gary. What are the jumpers labeled «Close 25mA/100mA jumpers for C.C.» for? Is there any connection to maybe lighten the backlight up a little? I just realized that it is quite dim compared to the 3.5" TFT you sell as well.
Thanks, Dani
adafruit2
Post by adafruit2 »
there's a constant current (C.C.) LED driver. by default we stick to safe 25mA. for 5", close the +25mA jumper as it looks best w/50mA draw!
