Is it possible to damage a few pixels on a neopixel ring? I have tried several variation of the sketch (Gemma, 12 pixel ring, powered over USB) but cannot get the last 5 pixels to light up. Only 0 through 6 power up and I can change colors, animate etc.
Details:
I received my first Gemma and neopixel ring (12 pixel) yesterday and promptly proceeded to test everything out late last night (in hindsight it was probably a bad idea :-))
The blink test on Gemma worked great, and so did the Slow Vibration Sensor Switch. I should have stopped there but felt encouraged with the success and proceeded to test the neopixel ring using alligator clips (not recommended, I know :-( )
As soon as i plugged the USB cable the ring flashed once and then the first pixel kept flashing red, I uploaded the sketch but it did not work. I unplugged and re-plugged the USB cable and this time nothing came back on (Gemma successfully powered up). I proceeded to check my wiring and realized that I have connected Gemma's vout to the neopixel's data out :-( (instead of power). I reconnected everything correctly and tried again, no luck.
To try and reset the wiring I connected small sections of solid core wires to the 3 pad on the neopixel ring (just twist tied, I don't have a soldering iron yet) and connected the alligator clips to that and then powered the setup again. This time the sketch ran, but only the first 7 pixels came on. I tried variations of the sketch, but could not get the last 5 pixels to power up.
Could this be because I have not soldered the wires to the ring? I have checked the wires and made them pretty tight using a pair of pliers.
Am I doing something incorrect in the code (I can post the sketch here if needed)?
What should I check/try next?
Thank you for your patience for reading through this post :-) Any help is greatly appreciated.
- a NeoPixel novice
Question about the 12 pixel neopixel ring
- adafruit_support_rick
Re: Question about the 12 pixel neopixel ring
Soldering would certainly help. Feel free to post your sketch, as well.
Was finally able to solder it all up last night, but that did not help, still only 7 leds (of the 12) light up.
Here is the sketch.
Here is the sketch.
#define PIN 2
// Parameter 1 = number of pixels in strip
// Parameter 2 = pin number (most are valid)
// Parameter 3 = pixel type flags, add together as needed:
// NEO_KHZ800 800 KHz bitstream (most NeoPixel products w/WS2812 LEDs)
// NEO_KHZ400 400 KHz (classic 'v1' (not v2) FLORA pixels, WS2811 drivers)
// NEO_GRB Pixels are wired for GRB bitstream (most NeoPixel products)
// NEO_RGB Pixels are wired for RGB bitstream (v1 FLORA pixels, not v2)
Adafruit_NeoPixel strip = Adafruit_NeoPixel(12, PIN, NEO_GRB + NEO_KHZ800);
strip.begin();
strip.setBrightness(20); //adjust brightness here
strip.show(); // Initialize all pixels to 'off'
// Some example procedures showing how to display to the pixels:
rainbow(20);
colorWipe(strip.Color(0, 0, 0), 0); // off
delay(2000);
cycleOnOff();
delay(2000);
cycleOn();
delay(2000);
rainbowCycle(20);
delay(5000);
// Fill the dots one after the other with a color
void colorWipe(uint32_t c, uint8_t wait) {
for(uint16_t i=0; i<strip.numPixels(); i++) {
strip.setPixelColor(i, c);
strip.show();
delay(wait);
void rainbow(uint8_t wait) {
uint16_t i, j;
for(j=0; j<256; j++) {
for(i=0; i<strip.numPixels(); i++) {
strip.setPixelColor(i, Wheel((i+j) & 255));
strip.show();
delay(wait);
// Slightly different, this makes the rainbow equally distributed throughout
void rainbowCycle(uint8_t wait) {
uint16_t i, j;
for(j=0; j<256*5; j++) { // 5 cycles of all colors on wheel
for(i=0; i< strip.numPixels(); i++) {
strip.setPixelColor(i, Wheel(((i * 256 / strip.numPixels()) + j) & 255));
strip.show();
delay(wait);
// Input a value 0 to 255 to get a color value.
// The colours are a transition r - g - b - back to r.
uint32_t Wheel(byte WheelPos) {
if(WheelPos < 85) {
return strip.Color(WheelPos * 3, 255 - WheelPos * 3, 0);
} else if(WheelPos < 170) {
WheelPos -= 85;
return strip.Color(255 - WheelPos * 3, 0, WheelPos * 3);
} else {
WheelPos -= 170;
return strip.Color(0, WheelPos * 3, 255 - WheelPos * 3);
//animate White, R, G, B individial pixel on then off
void cycleOnOff() {
colorWipe(strip.Color(255, 255, 255), 100); // white
colorWipe(strip.Color(0, 0, 0), 100); // off
colorWipe(strip.Color(255, 0, 0), 100); // Red
colorWipe(strip.Color(0, 255, 0), 100); // Green
colorWipe(strip.Color(0, 0, 255), 100); // Blue
void cycleOn() {
Please email [email protected] with a link to this thread for a replacement ring
