I create a program with arduino to monitor home current consumption and plot it on TFT display.
The TFT is controlled by arduino SPI.
When I plug power, 99% cases I have total white screen, and 1% cases the TFT works fine. So I have to switch on off the plug 100 times until the display works.
I tried to connect TFT reset pin together with arduino one, or I tried to keep it always to Vdd, or I tried to connect TFT reset to a dedicated arduino digital pin. No changes
Is it the case to try to control the display without SPI?
did this problem already happen?
Thanks,
Marco
problem with 1.8" TFT LCD display
- Attachments
- TFT example with working and not working cases
- TFT.JPG (116.5 KiB) Viewed 258 times
- adafruit_support_rick
Re: problem with 1.8" TFT LCD display
I don't think this is a problem with the reset line. I think you have a loose connection.
Check your soldering and your connections.
Also, try loading one of the example sketches which come with the Adafruit_ST7735 library. It may be that there's some conflict between the TFT and another part of your code.
