Hi Everyone,
I've got a Flora that is setup to output on an OLED display, as well as a NeoPixel Ring; but it can only output one or the other:
Parts:
Neopixel 24 Ring: https://www.adafruit.com/products/1586
128x64 SPI OLED Display: https://www.adafruit.com/product/661
The pins are setup as follows:
Ring GND -> Flora GND
Ring 5V -> Flora VBatt
Ring Data In -> Flora D12
Flora is USB powered for now
OLED Vin -> Flora 3.3V
OLED GND -> Flora GND
OLED DATA -> Flora D6
OLED CLK -> Flora D3
OLED DC -> Flora D10
OLED CS -> Flora D1
OLED RESET -> Flora D2
I can run the ssd1306_128x32_spi sketch no problem; and I can run the strandtest sketch, no problem; but I can't get both to output at the same time if I combine the sketches into one. Depending on which one I initialize first in the sketch, the other will remain dark. The code continues to run as if the OLED or ring are displaying as normal.
Hypothesis: Insufficient power or memory on the flora. Possibly a conflict with the pins I'm using. Or, worst case, my code.
Thanks!!
SPI OLED and NeoPixel Ring Conflict
- Franklin97355
Re: SPI OLED and NeoPixel Ring Conflict
It could be a memory issue. Could you post your code ?
Please use the code button "</>" or
tags when posting code to the forums.
- thechill
Code below. Again, I can run the sample codes independently (strandtest, ssd1306_128x32_spi) just fine on the same setup.
Note that using the below, the OLED works fine, but the LED ring won't respond to any setpixelcolor commands. I tried multiple pixel addresses (0-23) and RGB codes. Interestingly, if I run a piece of LED ring code beforehand (i.e., set the LED ring to all red), it retains this in memory and continues to show the red LED ring pattern even when I run the code below after it. That makes me think it's a memory issue rather than a power issue.
// SPI OLED Reqs
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define OLED_MOSI 6
#define OLED_CLK 3
#define OLED_DC 10
#define OLED_CS 1
#define OLED_RESET 2
Adafruit_SSD1306 display(OLED_MOSI, OLED_CLK, OLED_DC, OLED_RESET, OLED_CS);
#define NUMFLAKES 10
#define XPOS 0
#define YPOS 1
#define DELTAY 2
#define LOGO16_GLCD_HEIGHT 16
#define LOGO16_GLCD_WIDTH 16
// NeoPixel Ring Reqs
#define PIN 12
Adafruit_NeoPixel strip = Adafruit_NeoPixel(24, PIN, NEO_GRB + NEO_KHZ800);
// SETUP
Serial.begin(9600);
display.begin(SSD1306_SWITCHCAPVCC);
display.clearDisplay();
// Clear the buffer.
// The following won't work
strip.setPixelColor(1, strip.Color(255,255,0));
strip.show();
delay(100);
// MAIN
// Display on the OLED, this works
display.setTextSize(1);
display.setTextColor(WHITE);
display.setCursor(0,0);
display.println("This works, but my LED doesn't");
display.display();
delay(100);
// And this won't work here either
strip.setPixelColor(2, strip.Color(0,255,0));
strip.show();
delay(100);
- Franklin97355
You might take a look at this on Arduino memory management
- thechill
Well, my sketch compiles at 15K, well under the 28K flash limit with a bootloader. And the SRAM utilization according to this shouldn't be more than 1.1K, which is well under the 2.5K limit...
Not sure what it could be then...
- adafruit_support_rick
The compiler's estimate of SRAM usage isn't a very useful number. You want to include the freeRam function from the tutorial, and call it at the end of setup()
- adafruit2
Hmm that is odd. But not sure what it could be...it *might* be RAM but 24 pixels isn't very much. Do you have a logic analyzer or scope? would be useful to see if it even sends the data out the neopixel pin
- thechill
I get freeRam() reading back end of setup at 1432.
I unfortunately don't have a logic analyzer or a scope; I could probably get a general "something is happening" on my multimeter, but that's it.
Is this something you guys have seen before?
- pburgess
Just missing a strip.begin() in the setup() function, that should take care of it.
- thechill
: ( Embarrassing.
Thank you!!
Thank you!!
