red 1.2" 4-Digit 7-Segment Display w/I2C Backpack
roikr
Post by roikr »
connecting the display to rpi is not working properly:
1. when connecting VCC and V_IO to rpi 3.3v I get very dimmed display (dimmed digits !, colons are very bright)
2. when connecting VCC to rpi 5v and V_IO to rpi 3.3v I get no address (i2cdetect -y 1)
so I tried to connect V_IO to rpi 5v - got address but when I connected also VCC to 5v - the address gone.
what is going on ?
how can I get bright digits with rpi ?
10x,
Roee
Re: red 1.2" 4-Digit 7-Segment Display w/I2C Backpack
Please post photos showing your soldering and connections to the display.
roikr
Post by roikr »
connecting only V_IO to pi 3v (brown wire) - communication with dimmed light
disconnecting V_IO and connecting V_CC to pi 5v (red wire) - no communication but bright light
another strange behaviour, the backpack draw power also from scl and sda (if I disconnect V_CC and V_IO I still get light)
We need to see all the soldering on the board. Please post photos of the back of the board also.
Where do all the other wires in the photo go? You can't drive the display making only 1 connection at a time. All 5 wires are required to drive the display. Applying power to a circuit without a connected ground wire can damage the circuit.
GND - GND
VCC - 5v.
VIO - 3.3v
C - SCL
D - SDA
roikr
Post by roikr »
when I disconnected V_CC from the pi and measure its voltage, I got 2.8v
disconnecting V_IO from the pi and and test it, give 3.3v (when V_CC is connected)
is that ok ?
VCC is your main power to the board. You are probably just seeing some of the V_IO voltage leaking back through the circuit.
is that ok ?
That sounds right.
Your photos don't show your soldering to the display itself. What does the display do when fully wired?
roikr
Post by roikr »
my soldering...
when fully wired, i2cdetect -y 1 doesn't display the address.
Please contact [email protected] with a link to this thread and request a replacement backpack & display.
