Running separate WS2801 strands off of one Arduino?
- SubjectDelta
So, I have a strand of the 36MM and a strand of the 12MM WS2801 pixel strands. I've been using the Adafruit Arduino library to control one at a time, but I was wondering if there was any way to wire them into different pins on the Arduino and alter the code to run them as two individual matrices at the same time.
- Franklin97355
Re: Running separate WS2801 strands off of one Arduino?
You should be able to use this to start a string called "strip1" and then run another similar line changing the instance to "strip2"
int dataPin1 = 2;
int clockPin1 = 3;
int dataPin2 = 4;
int clockPin2 = 5;
// Set the first variable to the NUMBER of pixels. 25 = 25 pixels in a row
Adafruit_WS2801 strip1 = Adafruit_WS2801(25, dataPin1, clockPin1);
Adafruit_WS2801 strip2 = Adafruit_WS2801(25, dataPin2, clockPin2);
