I've assembled the quad alphanumeric display with i2c backpack, and am getting an issue with the lower right corner (both the bar and decimal point) not lighting up. I've checked solder joints, connections, chips and resistors and all seem to be good. I'm leaning to a bad decoder chip right now.
It's running off a 5v trinket, with the Vcc and Vi2c connected to the 5v output from the trinket
Any thoughts of what to check, or will I need an RMA for a bad chip?
Quad Alphanumeric Display issue
- Franklin97355
Re: Quad Alphanumeric Display issue
Could you post clear pictures of both sides of your board showing any soldering you have done and the connections to it?
- jj3
It's non-leaded solder, so a bit peaker than I'd like, but it's what I had on hand. Attached is both sides of the board:
It looks like you might have a couple of solder joints along the bottom of the photo that haven't wetted the pad completely.
Just to be sure, give any joint that isn't a nice cone a dab of flux and reheat it until it flows freely. If that doesn't help, we'll call it a bad chip.
- jj3
I fluxed and ran through all the solder joints on the board, same issue.
- Franklin97355
Please email [email protected] with a link to this thread for a replacement
- danlee58
I have 2 of these Quad Alphanumeric Displays. I am Writing to them over the I2C bus. I only have one unit on the bus, but have tried both with the same results. I get an Acknowledge when I Write to the unit from my Coridium SuperPro board, but I can't get any Segments to light on either board. The code was written in 'C'.
Can you post a copy of your I2C Address/Command/Data that you used to display the Zeros?
- jj3
I slightly modified the example "quadalphanum_mini" in the examples from the Adafruit LED Backpack library.
The basic code would be:
#include "Adafruit_LEDBackpack.h"
#include "Adafruit_GFX.h"
char *message = "**** 0000 ";
Adafruit_AlphaNum4 alpha4 = Adafruit_AlphaNum4();
alpha4.begin(0x70); // pass in the address
alpha4.clear();
alpha4.writeDisplay();
// send a message!
for (uint8_t i=0; i<strlen(message)-4; i++) {
alpha4.writeDigitAscii(0, message[i]);
alpha4.writeDigitAscii(1, message[i+1]);
alpha4.writeDigitAscii(2, message[i+2]);
alpha4.writeDigitAscii(3, message[i+3]);
delay(800); //So you have time to verify all the little bits are glowing properly
- jj3
Missed the ending }... apologies!
