NeoPixel NeoMatrix 8X8 Panel Fun
chemdoc77
Post by chemdoc77 »
How can you have fun with the NeoPixel NeoMatrix 8X8 Panel and a Trinket? You cannot use the NeoMatrix and GFX libraries since you do not have enough memory on the Trinket for these libraries. So what can you do? Use arrays and use an array of arrays along with new functions for those arrays!
Here is a video of a sketch run on a Trinket with the NeoPixel NeoMatrix 8X8 panel:
http://youtu.be/vPwUJIRed6U
Here is the code for that sketch on GitHub at:
https://github.com/chemdoc77/NeoPixel-N ... th-Trinket
After creating more arrays and more functions for the arrays, I had to use an Arduino Nano or Uno to run a second, more complex sketch since it would not run on the Trinket (probably not enough room in SRAM for the arrays and other stuff).
Here is a video of the second sketch run on an Arduino Nano with the NeoPixel NeoMatrix 8X8 panel:
http://youtu.be/qFvIE1fFoU0
https://github.com/chemdoc77/NeoPixel-N ... th-Arduino
Once I master putting arrays into flash memory and recalling them from flash memory to be used in an array of arrays then, I hope to get the second sketch working on a Trinket.
Best Regards,
Chemdoc77
adafruit_support_rick
Re: NeoPixel NeoMatrix 8X8 Panel Fun
Post by adafruit_support_rick »
Nice work! Thanks for posting! :)
