First of all, I hope I'm posting this in the correct part of the forums.
And secondly, my spelling isn't the best.
I bought the "5.6" Display & Audio 1280x800 (720p) Kit - HDMI/VGA/NTSC/PAL" (https://www.adafruit.com/products/1695) on october the 3rd. I didn't order the powe adapter becose I live in Europe, and the plug wouldn't work. I do have a charger that has a knob that if I turn, I can choose between 3, 4.5, 6, 7.5, 9 and 12 Volts. I can also switch the end plugs, obviously I read the power adapter description, so I placed on the 5.5/2.1mm.
Now, when I plug everything (5.5/2.1mm to 220 outlet) and the VGA to the back of the monitor. I notice that the LED on the board with buttons (don't know what it's called) isn't on. No lights on the driver board either. So I call a friend on skype, when I notice a plastic smell. Not the burning plastic kind, the smell of newly opened plastic stuff, like the inside of a video game of a CD/CVC dase. I touch the chip on the board and it's fairly warm. Not hot, so I don't think that's the problem.
Obviously the adapter is DC and I discharged the static everytime I was about to touch it. Am I doing something wrong, or have I broken it/got a dud?
Ordered 5.6" display 1695
- ziggah
Re: Ordered 5.6" display 1695
Something i forgot to mention one of the capacitors-or resistors or whatever it's called in english- has a hole in the what seems to be shrink wrap material. The other two are fine, and the rubber like material on them is fine, but
- ziggah
- ziggah
Something i forgot to mention one of the capacitors-or resistors or whatever it's called in english- has a hole in the what seems to be shrink wrap material. The other two are fine, and the rubber like material on them is fine, but the third one has a small hole in it and a slightly larger part of it seems to be damaged by heat. As I said before, I think that the rubbery stuff around it is shrinkwrap, so I think it was heated too much/soldering iron was placed too close, so that can't be the problem. Atleast I think so. I'm not sure how this thing is suppose to work correctly or how i get it set up the right way and I'm a bit tight on time with the project, so if anyone who knows how it's suppose to work can reply, that'd really save me.
- Franklin97355
Could you post clear pictures of both sides of your board showing any soldering you have done and the connections to it?
- ziggah
Sorry, didn't notice I made 4 replyes instead of just one, I didn't really know what I was doing.
No soldering, just plugged everyrhing in. I don't know how these boards are made, but I belive they have to be soldered by humans, and I thought someone heated the shrink wrap too much. I haven't done any soldering on my own. But I'll still provide pictures. They are made with my webcam, so the quality isn't very high.
I can't seem to find how to upload multile pictures or if I even can do that, so I'll just make more replyes.
This one here is the top of the board.
- Top of the board.PNG (718.6 KiB) Viewed 217 times
- ziggah
Bottom of the board
- Bottom of the board.PNG (717.32 KiB) Viewed 217 times
- ziggah
This was not caused by me, the only time i touched is when I was trying to turn it on.
I might be doing something wrong, so can you give me some instructions on how to set it up so it mirrors the image from the monitor?
- The capacitor.PNG (913.56 KiB) Viewed 217 times
