I am a little unclear on the pinouts for the https://www.adafruit.com/products/1673? ... ts_id=1673
I am not using an Arduino and I do not want to Plug and Pray.
I would follow the traces but they appear to be under the OLED itself.
Assumptions from GND to MOSI
? = Not for certain/best guess
GND: Ground,
Vin: Voltage In,
3vo: 3 Volt Out (regulated?),
CD: ?Card Detect?,
MISO: Master In Slave Out(SPI),
SCS: ?SD Chip Select?,
OCS: ?OLED Chip Select?,
RST: Reset(OLED),
DC: Data/Command(OLED),
CLK: Clock(SPI),
MOSI: Master Out Slave In(SPI)
Hope you can help.
Sincerely,
IdleGoose
PINOUTS for OLED BREAKOUT BOARD - 16-BIT COLOR 1.27" W/MICRO
- IdleGoose
- Franklin97355
Re: PINOUTS for OLED BREAKOUT BOARD - 16-BIT COLOR 1.27" W/M
Here are the Eagle files for the board https://github.com/adafruit/Adafruit-1. ... eakout-PCB
