Hi all,
I'm taking some NeoPixel strip and lining it on some stairs but I'm running in to some snags. I have everything wired properly but the NeoPixel strip fails to light up.
I have 248 Pixels in the strip but it won't light up unless I tell the sketch that it's only 110 Pixels. Anything more than that, the strip fails to load. I have the strip, with Flora (I've tried Gemma too) connected to an Apple iPad wall adapter.
Any ideas? Do I need more power?
Josh
Lots of NeoPixels
- Franklin97355
Re: Lots of NeoPixels
Could you post your code and a description or drawing of your connections between it all? Please use the code button "</>" or
tags when posting code to the forums. Also you may want to look over this on [url=https://learn.adafruit.com/memories-of-an-arduino]Arduino memory management[/url] as you may be running out of memory.
- joshstern
The code is merely the StrandTest with the correct number of Pixels:
#define PIN 6
// Parameter 1 = number of pixels in strip
// Parameter 2 = pin number (most are valid)
// Parameter 3 = pixel type flags, add together as needed:
// NEO_KHZ800 800 KHz bitstream (most NeoPixel products w/WS2812 LEDs)
// NEO_KHZ400 400 KHz (classic 'v1' (not v2) FLORA pixels, WS2811 drivers)
// NEO_GRB Pixels are wired for GRB bitstream (most NeoPixel products)
// NEO_RGB Pixels are wired for RGB bitstream (v1 FLORA pixels, not v2)
Adafruit_NeoPixel strip = Adafruit_NeoPixel(248, PIN, NEO_GRB + NEO_KHZ800);
strip.begin();
strip.show(); // Initialize all pixels to 'off'
// Some example procedures showing how to display to the pixels:
colorWipe(strip.Color(255, 0, 0), 50); // Red
colorWipe(strip.Color(0, 255, 0), 50); // Green
colorWipe(strip.Color(0, 0, 255), 50); // Blue
rainbow(20);
rainbowCycle(20);
// Fill the dots one after the other with a color
void colorWipe(uint32_t c, uint8_t wait) {
for(uint16_t i=0; i<strip.numPixels(); i++) {
strip.setPixelColor(i, c);
strip.show();
delay(wait);
void rainbow(uint8_t wait) {
uint16_t i, j;
for(j=0; j<256; j++) {
for(i=0; i<strip.numPixels(); i++) {
strip.setPixelColor(i, Wheel((i+j) & 255));
strip.show();
delay(wait);
// Slightly different, this makes the rainbow equally distributed throughout
void rainbowCycle(uint8_t wait) {
uint16_t i, j;
for(j=0; j<256*5; j++) { // 5 cycles of all colors on wheel
for(i=0; i< strip.numPixels(); i++) {
strip.setPixelColor(i, Wheel(((i * 256 / strip.numPixels()) + j) & 255));
strip.show();
delay(wait);
// Input a value 0 to 255 to get a color value.
// The colours are a transition r - g - b - back to r.
uint32_t Wheel(byte WheelPos) {
if(WheelPos < 85) {
return strip.Color(WheelPos * 3, 255 - WheelPos * 3, 0);
} else if(WheelPos < 170) {
WheelPos -= 85;
return strip.Color(255 - WheelPos * 3, 0, WheelPos * 3);
} else {
WheelPos -= 170;
return strip.Color(0, WheelPos * 3, 255 - WheelPos * 3);
- adafruit_support_bill
I'd suspect a power problem. 248 pixels could pull as much as 15 amps at max intensity. Running StrandTest probably requires about 1/2 to 1/3 of that. Still probably more than your wall adapter is capable of supplying.I have the strip, with Flora (I've tried Gemma too) connected to an Apple iPad wall adapter.
Running out of SRAM is another possibility. (Definitely too many pixels for a Gemma) The tutorial link posted by Franklin has some advice on diagnosing memory problems.
- chemdoc77
Hi Josh:
You might be able to find out if your problem is a power problem by changing the loop in your sketch to a lower brightness like this:
If it runs all of the pixels then you have a power problem.
Did you check that you have 5 volts at the end of the strip?
Recently, I had a SRAM problem when a sketch that ran on a Uno would not run on a Trinket. I am in the process of trying to lower the SRAM amount in that sketch so that it will run on a Trinket.
Best Regards,
Chemdoc77
colorWipe(strip.Color(15, 0, 0), 50); // Red
colorWipe(strip.Color(0, 15, 0), 50); // Green
colorWipe(strip.Color(0, 0, 15), 50); // Blue
//rainbow(20);
//rainbowCycle(20);
Best Regards,
Chemdoc77
