Neopixel and Firmata
Hi. I have a project that uses an Arduino Uno and Firmata, and I was wondering if it is possible to modify Firmata to use the Adafruit Neopixel library, or if there is any way to use Neopixels without modifying. Has anyone ever done this before?
- adafruit_support_rick
Re: Neopixel and Firmata
You can't drive neopixels directly with Firmata. However, you could arrange a simple protocol. For example, you could use the Firmata sendSysex function to send a set of pixel colors. The Arduino would need a simple loop to assign the pixel colors.
Alright. I think I might be able to send the message, but how do I receive it in Firmata and do something with it?
Please refer to the Firmata documentation:
http://arduino.cc/en/reference/firmata
sendSysex sends an arbitrary array of bytes. You implement a sysex callback function, and attach it to Firmata using the attach function:
You format the data in the array any way you like. Simplest would be a series of r, g, b values, one for each NeoPixel. Then you can just loop through the array and write each set of r, g, b to each pixel in your system.
where "command" is "SYSEX_START" and "myFunction" is the name a function of the formattach(byte command, callbackFunction myFunction)
attach a function to an incoming message type
In your loop function, call processInput to dispatch incoming messages to your callback function:void sysexCallbackFunction(byte pin, byte byteCount, byte *arrayPointer);
while(Firmata.available()) {
Firmata.processInput();
- christopherv
To get the WS2812's 800KHz timing right, the Adafruit_NeoPixel library resorts to assembly code. Has anyone actually implemented this in the context of the Firmata protocol? I'd like to have students program NeoPixel rings using Scratch (scratchx.org) and would prefer not to reinvent the wheel if it's already been done! Thanks.
- t_serkov
Hello, I'm also trying to make some light over Firmata and Neopixel library.
Presently nothing works, what am I doing wrong?
#include <Firmata.h>
#define PIN 6
// How many NeoPixels are attached to the Arduino?
#define NUMPIXELS 16
Adafruit_NeoPixel pixels = Adafruit_NeoPixel(NUMPIXELS, PIN, NEO_GRB + NEO_KHZ800);
//void sysexCallbackFunction(byte pin, byte byteCount, byte *arrayPointer);
void sysexCallback(byte num, byte argc, byte *argv)
pixels.begin();
pixels.setPixelColor(num, pixels.Color(argc, argc, argv[1]));
// put your setup code here, to run once:
Firmata.attach(START_SYSEX, sysexCallback);
Firmata.begin();
// put your main code here, to run repeatedly:
while (Firmata.available()) {
When you say, "nothing works", what exactly do you mean? Are you getting compilation errors? Does it compile and upload but the NeoPixels don't respond?
Your callback isn't right. argc is the argument count. And you want pixels.begin in setup, not in your callback. You should be doing this:
pixels.setPixelColor(num, pixels.Color(argv[0], argv[1], argv[2]));
pixels.begin();
Firmata.attach(START_SYSEX, sysexCallback); //shouldn't this be SYSEX_START?
Firmata.begin();
