DisplayPort to HDMI for HDMI 4 Pi - 10.1" Display 1280x800 I
meir
Post by meir »
Your item: https://www.adafruit.com/products/1287 states:
To demonstrate it, we took some photos with the display connected to a Raspberry Pi, but it will also work connected to any device with HDMI, VGA or NTSC/PAL output. It will not work with a device that only outputs DVI (without a DVI to HDMI converter) or SECAM.
If my computer has a DisplayPort and I use a DisplayPort to HDMI cable - will it work? (http://www.amazon.com/gp/product/B004C9 ... UTF8&psc=1)
Franklin97355
Re: DisplayPort to HDMI for HDMI 4 Pi - 10.1" Display 1280x8
Post by Franklin97355 »
If the cable does what it says it does it should work. If you feed the display true HDMI it will work.
