I have received my Monochrome 0.96" 128x64 OLED graphic display and I have also purchased an RFDUINO.
I have downloaded both of the Adafruit_SSD1306 and the Adafruit_GFX librarys.
I have the 1.5.7 IDE software from Arduino.
I tried compiling the example file for I2C for the OLED and encountered the following error.
Arduino: 1.5.7 (Windows 7), Board: "RFduino"
Build options changed, rebuilding all
Using library SPI in folder: C:\Program Files (x86)\Arduino\hardware\arduino\RFduino\libraries\SPI (legacy)
Using library Wire in folder: C:\Program Files (x86)\Arduino\hardware\arduino\RFduino\libraries\Wire (legacy)
Using library Adafruit-GFX-Library-master in folder: C:\Program Files (x86)\Arduino\libraries\Adafruit-GFX-Library-master (legacy)
Using library Adafruit_SSD1306-master in folder: C:\Program Files (x86)\Arduino\libraries\Adafruit_SSD1306-master (legacy)
C:\Program Files (x86)\Arduino/hardware/tools/gcc-arm-none-eabi-4.8.3-2014q1/bin/arm-none-eabi-g++ -c -g -Os -w -ffunction-sections -fdata-sections -fno-rtti -fno-exceptions -fno-builtin -mcpu=cortex-m0 -DF_CPU=16000000 -DARDUINO=157 -mthumb -D__RFduino__ -IC:\Program Files (x86)\Arduino\hardware\arduino\RFduino\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\RFduino\variants\RFduino -IC:\Program Files (x86)\Arduino\hardware\arduino\RFduino\libraries\SPI -IC:\Program Files (x86)\Arduino\hardware\arduino\RFduino\libraries\Wire -IC:\Program Files (x86)\Arduino\libraries\Adafruit-GFX-Library-master -IC:\Program Files (x86)\Arduino\libraries\Adafruit_SSD1306-master -IC:\Program Files (x86)\Arduino\hardware\arduino\RFduino\system/RFduino -IC:\Program Files (x86)\Arduino\hardware\arduino\RFduino\system/RFduino/include -IC:\Program Files (x86)\Arduino\hardware\arduino\RFduino\system/CMSIS/CMSIS/Include C:\Users\MMN\AppData\Local\Temp\build1254918803555975293.tmp\ssd1306_128x64_i2c.cpp -o C:\Users\MMN\AppData\Local\Temp\build1254918803555975293.tmp\ssd1306_128x64_i2c.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/gcc-arm-none-eabi-4.8.3-2014q1/bin/arm-none-eabi-g++ -c -g -Os -w -ffunction-sections -fdata-sections -fno-rtti -fno-exceptions -fno-builtin -mcpu=cortex-m0 -DF_CPU=16000000 -DARDUINO=157 -mthumb -D__RFduino__ -IC:\Program Files (x86)\Arduino\hardware\arduino\RFduino\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\RFduino\variants\RFduino -IC:\Program Files (x86)\Arduino\hardware\arduino\RFduino\libraries\SPI -IC:\Program Files (x86)\Arduino\hardware\arduino\RFduino\libraries\Wire -IC:\Program Files (x86)\Arduino\libraries\Adafruit-GFX-Library-master -IC:\Program Files (x86)\Arduino\libraries\Adafruit_SSD1306-master -IC:\Program Files (x86)\Arduino\hardware\arduino\RFduino\libraries\SPI\utility -IC:\Program Files (x86)\Arduino\hardware\arduino\RFduino\system/RFduino -IC:\Program Files (x86)\Arduino\hardware\arduino\RFduino\system/RFduino/include -IC:\Program Files (x86)\Arduino\hardware\arduino\RFduino\system/CMSIS/CMSIS/Include C:\Program Files (x86)\Arduino\hardware\arduino\RFduino\libraries\SPI\SPI.cpp -o C:\Users\MMN\AppData\Local\Temp\build1254918803555975293.tmp\SPI\SPI.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/gcc-arm-none-eabi-4.8.3-2014q1/bin/arm-none-eabi-g++ -c -g -Os -w -ffunction-sections -fdata-sections -fno-rtti -fno-exceptions -fno-builtin -mcpu=cortex-m0 -DF_CPU=16000000 -DARDUINO=157 -mthumb -D__RFduino__ -IC:\Program Files (x86)\Arduino\hardware\arduino\RFduino\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\RFduino\variants\RFduino -IC:\Program Files (x86)\Arduino\hardware\arduino\RFduino\libraries\SPI -IC:\Program Files (x86)\Arduino\hardware\arduino\RFduino\libraries\Wire -IC:\Program Files (x86)\Arduino\libraries\Adafruit-GFX-Library-master -IC:\Program Files (x86)\Arduino\libraries\Adafruit_SSD1306-master -IC:\Program Files (x86)\Arduino\hardware\arduino\RFduino\libraries\Wire\utility -IC:\Program Files (x86)\Arduino\hardware\arduino\RFduino\system/RFduino -IC:\Program Files (x86)\Arduino\hardware\arduino\RFduino\system/RFduino/include -IC:\Program Files (x86)\Arduino\hardware\arduino\RFduino\system/CMSIS/CMSIS/Include C:\Program Files (x86)\Arduino\hardware\arduino\RFduino\libraries\Wire\Wire.cpp -o C:\Users\MMN\AppData\Local\Temp\build1254918803555975293.tmp\Wire\Wire.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/gcc-arm-none-eabi-4.8.3-2014q1/bin/arm-none-eabi-gcc -c -g -Os -w -ffunction-sections -fdata-sections -fno-builtin -mcpu=cortex-m0 -DF_CPU=16000000 -DARDUINO=157 -mthumb -D__RFduino__ -IC:\Program Files (x86)\Arduino\hardware\arduino\RFduino\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\RFduino\variants\RFduino -IC:\Program Files (x86)\Arduino\hardware\arduino\RFduino\libraries\SPI -IC:\Program Files (x86)\Arduino\hardware\arduino\RFduino\libraries\Wire -IC:\Program Files (x86)\Arduino\libraries\Adafruit-GFX-Library-master -IC:\Program Files (x86)\Arduino\libraries\Adafruit_SSD1306-master -IC:\Program Files (x86)\Arduino\libraries\Adafruit-GFX-Library-master\utility -IC:\Program Files (x86)\Arduino\hardware\arduino\RFduino\system/RFduino -IC:\Program Files (x86)\Arduino\hardware\arduino\RFduino\system/RFduino/include -IC:\Program Files (x86)\Arduino\hardware\arduino\RFduino\system/CMSIS/CMSIS/Include C:\Program Files (x86)\Arduino\libraries\Adafruit-GFX-Library-master\glcdfont.c -o C:\Users\MMN\AppData\Local\Temp\build1254918803555975293.tmp\Adafruit-GFX-Library-master\glcdfont.c.o
C:\Program Files (x86)\Arduino/hardware/tools/gcc-arm-none-eabi-4.8.3-2014q1/bin/arm-none-eabi-g++ -c -g -Os -w -ffunction-sections -fdata-sections -fno-rtti -fno-exceptions -fno-builtin -mcpu=cortex-m0 -DF_CPU=16000000 -DARDUINO=157 -mthumb -D__RFduino__ -IC:\Program Files (x86)\Arduino\hardware\arduino\RFduino\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\RFduino\variants\RFduino -IC:\Program Files (x86)\Arduino\hardware\arduino\RFduino\libraries\SPI -IC:\Program Files (x86)\Arduino\hardware\arduino\RFduino\libraries\Wire -IC:\Program Files (x86)\Arduino\libraries\Adafruit-GFX-Library-master -IC:\Program Files (x86)\Arduino\libraries\Adafruit_SSD1306-master -IC:\Program Files (x86)\Arduino\libraries\Adafruit-GFX-Library-master\utility -IC:\Program Files (x86)\Arduino\hardware\arduino\RFduino\system/RFduino -IC:\Program Files (x86)\Arduino\hardware\arduino\RFduino\system/RFduino/include -IC:\Program Files (x86)\Arduino\hardware\arduino\RFduino\system/CMSIS/CMSIS/Include C:\Program Files (x86)\Arduino\libraries\Adafruit-GFX-Library-master\Adafruit_GFX.cpp -o C:\Users\MMN\AppData\Local\Temp\build1254918803555975293.tmp\Adafruit-GFX-Library-master\Adafruit_GFX.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/gcc-arm-none-eabi-4.8.3-2014q1/bin/arm-none-eabi-g++ -c -g -Os -w -ffunction-sections -fdata-sections -fno-rtti -fno-exceptions -fno-builtin -mcpu=cortex-m0 -DF_CPU=16000000 -DARDUINO=157 -mthumb -D__RFduino__ -IC:\Program Files (x86)\Arduino\hardware\arduino\RFduino\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\RFduino\variants\RFduino -IC:\Program Files (x86)\Arduino\hardware\arduino\RFduino\libraries\SPI -IC:\Program Files (x86)\Arduino\hardware\arduino\RFduino\libraries\Wire -IC:\Program Files (x86)\Arduino\libraries\Adafruit-GFX-Library-master -IC:\Program Files (x86)\Arduino\libraries\Adafruit_SSD1306-master -IC:\Program Files (x86)\Arduino\libraries\Adafruit_SSD1306-master\utility -IC:\Program Files (x86)\Arduino\hardware\arduino\RFduino\system/RFduino -IC:\Program Files (x86)\Arduino\hardware\arduino\RFduino\system/RFduino/include -IC:\Program Files (x86)\Arduino\hardware\arduino\RFduino\system/CMSIS/CMSIS/Include C:\Program Files (x86)\Arduino\libraries\Adafruit_SSD1306-master\Adafruit_SSD1306.cpp -o C:\Users\MMN\AppData\Local\Temp\build1254918803555975293.tmp\Adafruit_SSD1306-master\Adafruit_SSD1306.cpp.o
C:\Program Files (x86)\Arduino\libraries\Adafruit_SSD1306-master\Adafruit_SSD1306.cpp:21:24: fatal error: util/delay.h: No such file or directory
#include <util/delay.h>
compilation terminated.
Do I need a new library for the RFDUINO and the SSD1306?
Is Adafruit able to provide me with the Library file? I have looked at the Gitlab website and can not find anything relating to this issue.
Your help is much appreciated.
