All,
I am building the WiFi Pandora Radio project, and all works well except for one modification.
The LCD and Backpack are mounted to the top of an enclosure, and I am trying to use ribbon cable to connect it to the Pi. Seeing as though both ends are female, I purchased some male headers. When I attach the male headers, I get an input/output error for the LCD. The LCD doesn't light up, and.... that's that.
If I remove the ribbon cable and male headers and attach the Pi to the LCD directly, the script works fine.
How can I use ribbon cable in this example, OR, what would you folks recommend I use to support the Pi to the top of the box, hanging down from the LCD?
Pi I2c backpack
- Franklin97355
Re: Pi I2c backpack
Could you post some pictures of the connections? Are you sure you are getting solid connections and you have the pins going to the correct header locations?
Re: Pi I2c backpack
I'm using the male headers from Adafruit (PID 400) and the connection feels tight and secure. However, the LCD doesn't illuminate.
- Franklin97355
Re: Pi I2c backpack
Test your cable. Make sure pin 1 on the pi end is mating with pin 1 on the TFT end.
