Hi
My Setup : WS2801 2x 50 LED Strips
Arduino Uno
Power Supply 8A 5V
I connected the Powers Supply at the End of each Strip
I am using Boblight with the Boblight Plugin and Openelec.
And my Problem is that the LED´s are flickering / and have the wrong Color.
This happen not the hole Time , but it happens very offen :(
What have i done wrong ?
WS2801 + Arudino Uno Lights flickering
Re: WS2801 + Arudino Uno Lights flickering
Intermittent problems like that are most often due to a bad connection somewhere. Check all your solder joints.This happen not the hole Time , but it happens very offen
Ok, i will check the connection . but there are no solder points . i have a Adapter. But maybe boblight is the Problem ? Because at the Start the 3 colors light up correctly . but when boblight xbmc starts the 3 colors light up a little bit flickering and a bit wrong.
Or maybe its the powersuplly ? Can i connectd the piwersupply at each beginning and end oft the strip ?
I'm not familiar with the boblight. But there is no problem supplying power to both ends. In fact that is recommended for longer strips.
