OLED 128x32 with Arduino Micro
- scottwoyak
Hi, I've been using an OLED display with an UNO and love the display. I tried to package up my application with a Micro through and the OLED didn't work. After doing some research I think the Micro doesn't support SPI. Is there a way to get the OLED display to work with the Micro?
- adafruit_support_rick
Re: OLED 128x32 with Arduino Micro
The Micro supports SPI, but not through pins 11, 12, and 13. You have to use the dedicated SPI pins. They are on the end of the board opposite the USB plug. Look for pins labeled MO (MOSI), MI (MISO), and SCK.
- scottwoyak
Thank you very much. I wired things up like the Micro was a Uno, but it is actually a Leonardo. After changing things around everything works!
- brunncyr
Hi
I am having the same problems... did you have to adapt something in the programm? Could you share your code as well as your wiring?
Thank you very much
Cyril
Thank you very much
Cyril
All you need to do is wire according to the earlier post:
Can you post a picture of your OLED and your wiring?The Micro supports SPI, but not through pins 11, 12, and 13. You have to use the dedicated SPI pins. They are on the end of the board opposite the USB plug. Look for pins labeled MO (MOSI), MI (MISO), and SCK.
- scottwoyak
I don't have a picture anymore - on to my next project already. Take a look at the diagram on this page though: http://arduino.cc/en/Main/arduinoBoardMicro
You can either hook up the pins via the dedicated ICSP header as previously stated or, if you're using a breadboard, just use the pins from the diagram in the above.
DATA = MOSI
CLK = SCK
Lastly, in your code you need to use the hardware SPI constructor shown below. The Adafruit tutorial uses software SPI and uses custom pins for MOSI and SCK.
Adafruit_SSD1306 display(OLED_DC, OLED_RESET, OLED_CS);
The D/C, RST, and CS can be digital pins of your choice
DATA = MOSI
CLK = SCK
