I have used (NEO_RGB + NEO_KHZ800) for the third parameter of the NeoPixel constructor however it appears to be using the default:
(NEO_GRB + NEO_KHZ800).
I've tested with:
ff = Blue
ff00 = Red
ff0000 = Green
I would expect ff0000 to be red as per my setting, but red and green seem swapped.
I'm not sure why and I will continue to investigate.
NeoPixel RGB order
Re: NeoPixel RGB order
The third parameter specifies the color ordering used by the pixels, not the API. The API is always RGB. Some pixels are RGB and some are GRB. If the colors appear reversed using the RGB option, than your pixels are GRB.
- splatten
Thank you, this explains it!
- splatten
Turns out that my 24 Neopixel ring is ordered GRB and the 16 Neopixel ring is ordered BRG.
Hadn't noticed this before as to date I've been using fading transistions and not noticed that the base colours were different.
Now I'm setting the colour according to temperature.
Is this normal, is the mode of the Neopixel's set to a standard or random?
