HDMI 5'' Display Backpack with Touchscreen, touchscreen isn'
fhlipzero
Re: HDMI 5'' Display Backpack with Touchscreen, touchscreen
Post by fhlipzero »
yea definitely real, it has trouble giving the virtual machine control of the screen since it technically sees it as just a mouse, good thing I had an old pc with hdmi laying around
kuky
Post by kuky »
HI
Just got mine, does not work as Touch on Pi
I plugged it on Windows and Mac using same cables - works fine on both and it seems pretty calibrated
Do I have to install anything other then a fresh Raspbian image?
Since it works on both Win and Mac do I need to recalibrate?
i tried ...
I did download ARConfigurationUtility and started it but its window is way bigger and cannot be resized
Then I tried with 2 Monitors HDMI being the main
I cannot drag the huge window of the Cal Utility to 2nd screen to resize it
Any other windows i did open are draggable
No idea what to do next
BTW - the touch LED blinks same speed on Pik as on Win when "touched" but no reaction on the screen
thx
adafruit2
Post by adafruit2 »
kuy, the pi USB ports sometimes have difficulty, you can use 'sudo lsusb' to make sure it can see the AR1100 mouse, you can also run the calibration utility on a 'second monitor' follow the directions here
https://learn.adafruit.com/ar1100-resis ... the-ar1100
kuky
Post by kuky »
Yep
Did dmesg and didn't see it
So I found another pc and run the Calibration and Changed to USB mouse form I2C
Got it to work eventually
thx
kuky
Post by kuky »
THIS IS a real pain you know where!!!
Was working fine yesterday, I did shut it down and unplugged everything BUT NOW is NOT'
Does NOT show in dmesg
I plugged it back on the Win machine
Run the calibration which NOW always defaults to 5 wires no matter how many times i set it up to 4
Did the calibration
Was ok on windows
Plugged back on the SAME pi - NOT working
Beyond annoying and frustrating
kuky
Post by kuky »
Some progress
Restarted everything from scratch - with a new SD, new raspbian install ..etc
seems to work .. let's see for how long...
kuky
Post by kuky »
Hmm..
Shutdown RPi and unplugged the power and everything else
Plugged everything back
Restarted
No touch again!!!
kuky
Post by kuky »
Interesting
I had no idea that IT DOERS MATTER which USB port the TFT is plugged in
Tried 3x with same result
If the USB is changed ( I have 2 on R-pi B ) from the port used on 'initial' setup of the TFT the Touch doers NOT work
Is this Normal?
Supermathew
Post by Supermathew »
Hi Kuky
So your touchscreen does work properly, when you allways connect the screen at the same usb port? Are you talking about the white usb or the usb mini b from the touchscreen controller board?
Have you plugt all 3 cables (HDMI, usb-power(white one) and the usb mini b) into your raspberry pi?
Thanks for an answer!
kuky
Post by kuky »
Do you think I remember? ;)
The Touch/power mini USB cable goers in the Rpi. That's it
Is there any other option?
What white usb?
What 3 cables?
Are we talking about the same unit?
Mine has 2 ports 1 HDMi and 1 mini usb for touch/power
And yes it works fine - is a very nice screen BTW
Supermathew
Hi there
I'm using this one: https://www.adafruit.com/products/2109
Not the same as yours?
There are 3 cables, but I acctualy found maybey in another post a possible solution. Will give a try later.
Thanks for your fast reply! ;)
kuky
Post by kuky »
Ha! Of course NOT
D id you see the title of this Thread?
"HDMI 5'' Display Backpack with Touchscreen, .....
That's a different model
https://www.adafruit.com/product/2260
rupert
Post by rupert »
I am having exactly the same issue as kuky.
The screen is calibrated and working fine through windows
When I press on the screen when connected to RPI the led responds but nothing happens on screen.
Please can Adafruit advise what is going on.
kuky wrote:THIS IS a real pain you know where!!!
Did the calibration
Was ok on windows
Supermathew
The touch works now! I used the raspbian Image, there was no problem with the touch.
I installed on the raspbian an xbmc-os, but there is the touch not working properly.
When I touch the screen, xbmc react like something was touched, but no on the position, I touched.
Example:
Touch the middle of the screen, the settings in the left corner opens. And yes ;), the screen is calibrated correctly!
I will fix this on my own!
Thanks for your adviceses, will stay activ in this post, if someone else has any troubles ;)
rupert
Post by rupert »
How can this be considered an acceptable solution
The screen is marketed as being raspberry pi compatible - to quote Adafruit - "In particular, we suggest it for use with single board computers (or desktop/laptops!) with DVI/HDMI output like the Raspberry Pi"
What is the point if it does not work on xbmc which specifically allows touchscreen support.
Again - Please can Adafruit advise.
Supermathew wrote:The touch works now! I used the raspbian Image, there was no problem with the touch.
Example:
