I've been trying to get the subject to display a full array of 32 characters on a 16x2 display using the sample code provided at:
https://learn.adafruit.com/usb-plus-ser ... ttl-serial
If you replace:
cd.print(" - Adafruit");
with a string of 16 characters like:
cd.print(" - Adafruit23456");
It will only display the second line. If you remove the "6" in the line above, it works fine. How do you overcome this limitation? Thanks.
USB + Serial RGB Backlight Character LCD Backpack Character
- noman
- adafruit2
Re: USB + Serial RGB Backlight Character LCD Backpack Charac
try turning off autowrap?
https://learn.adafruit.com/usb-plus-ser ... -reference
search for "auto-line-wrap off"
- noman
This worked, but you also have to change the "println" to "print". Thanks for the support!
