[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 3.12.26+ (ladyada@ladyada-VirtualBox) (gcc version 4.4.7 (Ubuntu/Linaro 4.4.7-1ubuntu2) ) #7 PREEMPT Wed Sep 17 14:25:24 EDT 2014
[ 0.000000] CPU: ARMv6-compatible processor [410fb767] revision 7 (ARMv7), cr=00c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
[ 0.000000] Machine: BCM2708
[ 0.000000] cma: CMA: reserved 8 MiB at 1b800000
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] On node 0 totalpages: 114688
[ 0.000000] free_area_init_node: node 0, pgdat c0670468, node_mem_map c0721000
[ 0.000000] Normal zone: 896 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 114688 pages, LIFO batch:31
[ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 113792
[ 0.000000] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708.boardrev=0xe bcm2708.serial=0xf6741063 smsc95xx.macaddr=B8:27:EB:74:10:63 sdhci-bcm2708.emmc_clock_freq=250000000 vc_mem.mem_base=0x1ec00000 vc_mem.mem_size=0x20000000 dwc_otg.lpm_enable=0 console=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline rootwait fbcon=map:10 fbcon=font:VGA8x8
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Memory: 439204K/458752K available (4815K kernel code, 243K rwdata, 1352K rodata, 146K init, 701K bss, 19548K reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] vmalloc : 0xdc800000 - 0xff000000 ( 552 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xdc000000 ( 448 MB)
[ 0.000000] modules : 0xbf000000 - 0xc0000000 ( 16 MB)
[ 0.000000] .text : 0xc0008000 - 0xc060dee4 (6168 kB)
[ 0.000000] .init : 0xc060e000 - 0xc0632a44 ( 147 kB)
[ 0.000000] .data : 0xc0634000 - 0xc0670d60 ( 244 kB)
[ 0.000000] .bss : 0xc0670d6c - 0xc0720228 ( 702 kB)
[ 0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] NR_IRQS:394
[ 0.000000] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 4294967ms
[ 0.000000] Switching to timer-based delay loop
[ 0.000000] Console: colour dummy device 80x30
[ 0.000000] console [tty1] enabled
[ 0.001259] Calibrating delay loop (skipped), value calculated using timer frequency.. 2.00 BogoMIPS (lpj=10000)
[ 0.001323] pid_max: default: 32768 minimum: 301
[ 0.001776] Mount-cache hash table entries: 512
[ 0.002579] Initializing cgroup subsys memory
[ 0.002690] Initializing cgroup subsys devices
[ 0.002732] Initializing cgroup subsys freezer
[ 0.002766] Initializing cgroup subsys blkio
[ 0.002904] CPU: Testing write buffer coherency: ok
[ 0.003397] Setting up static identity map for 0xc04965e0 - 0xc049663c
[ 0.005321] devtmpfs: initialized
[ 0.021543] VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
[ 0.023171] NET: Registered protocol family 16
[ 0.028575] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[ 0.029292] cpuidle: using governor ladder
[ 0.029345] cpuidle: using governor menu
[ 0.029798] bcm2708.uart_clock = 0
[ 0.031877] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
[ 0.031942] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.031979] mailbox: Broadcom VideoCore Mailbox driver
[ 0.032083] bcm2708_vcio: mailbox at f200b880
[ 0.032195] bcm_power: Broadcom power driver
[ 0.032237] bcm_power_open() -> 0
[ 0.032265] bcm_power_request(0, 8)
[ 0.532987] bcm_mailbox_read -> 00000080, 0
[ 0.533032] bcm_power_request -> 0
[ 0.533232] Serial: AMBA PL011 UART driver
[ 0.533423] dev:f1: ttyAMA0 at MMIO 0x20201000 (irq = 83, base_baud = 0) is a PL011 rev3
[ 0.891029] console [ttyAMA0] enabled
[ 0.917705] bio: create slab <bio-0> at 0
[ 0.923448] SCSI subsystem initialized
[ 0.927481] usbcore: registered new interface driver usbfs
[ 0.933204] usbcore: registered new interface driver hub
[ 0.938790] usbcore: registered new device driver usb
[ 0.945436] Switched to clocksource stc
[ 0.949708] FS-Cache: Loaded
[ 0.952882] CacheFiles: Loaded
[ 0.969082] NET: Registered protocol family 2
[ 0.974561] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.981992] TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.988573] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.995026] TCP: reno registered
[ 0.998330] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 1.004204] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 1.010919] NET: Registered protocol family 1
[ 1.015943] RPC: Registered named UNIX socket transport module.
[ 1.021907] RPC: Registered udp transport module.
[ 1.026727] RPC: Registered tcp transport module.
[ 1.031454] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.038903] bcm2708_dma: DMA manager at f2007000
[ 1.043667] bcm2708_gpio: bcm2708_gpio_probe c0641e70
[ 1.049223] vc-mem: phys_addr:0x00000000 mem_base=0x1ec00000 mem_size:0x20000000(512 MiB)
[ 1.058803] audit: initializing netlink socket (disabled)
[ 1.064315] type=2000 audit(0.910:1): initialized
[ 1.239962] VFS: Disk quotas dquot_6.5.2
[ 1.244237] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 1.253192] FS-Cache: Netfs 'nfs' registered for caching
[ 1.260144] NFS: Registering the id_resolver key type
[ 1.265315] Key type id_resolver registered
[ 1.269646] Key type id_legacy registered
[ 1.274398] msgmni has been set to 873
[ 1.280241] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ 1.288121] io scheduler noop registered
[ 1.292081] io scheduler deadline registered (default)
[ 1.297711] io scheduler cfq registered
[ 1.302807] BCM2708FB: allocated DMA memory 5bc00000
[ 1.308012] BCM2708FB: allocated DMA channel 0 @ f2007000
[ 1.317807] Console: switching to colour frame buffer device 82x52
[ 1.327046] bcm2708-dmaengine bcm2708-dmaengine: Load BCM2835 DMA engine driver
[ 1.334817] uart-pl011 dev:f1: no DMA platform data
[ 1.340578] vc-cma: Videocore CMA driver
[ 1.344577] vc-cma: vc_cma_base = 0x00000000
[ 1.349457] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
[ 1.354928] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
[ 1.369968] brd: module loaded
[ 1.378378] loop: module loaded
[ 1.381869] vchiq: vchiq_init_state: slot_zero = 0xdb800000, is_master = 0
[ 1.389892] Loading iSCSI transport class v2.0-870.
[ 1.396160] usbcore: registered new interface driver smsc95xx
[ 1.402251] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.609815] Core Release: 2.80a
[ 1.614432] Setting default values for core params
[ 1.620756] Finished setting default values for core params
[ 1.827854] Using Buffer DMA mode
[ 1.832614] Periodic Transfer Interrupt Enhancement - disabled
[ 1.839899] Multiprocessor Interrupt Enhancement - disabled
[ 1.846927] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 1.852727] Dedicated Tx FIFOs mode
[ 1.858091] WARN::dwc_otg_hcd_init:1042: FIQ DMA bounce buffers: virt = 0xdbc14000 dma = 0x5bc14000 len=9024
[ 1.870892] FIQ FSM acceleration enabled for :
[ 1.870892] Non-periodic Split Transactions
[ 1.870892] Periodic Split Transactions
[ 1.870892] High-Speed Isochronous Endpoints
[ 1.893165] dwc_otg: Microframe scheduler enabled
[ 1.893269] WARN::hcd_init:473: FIQ at 0xc0364444
[ 1.899455] WARN::hcd_init:474: FIQ ASM at 0xc0364858 length 36
[ 1.906912] WARN::hcd_init:500: MPHI regs_base at 0xdc806000
[ 1.913972] dwc_otg bcm2708_usb: DWC OTG Controller
[ 1.920319] dwc_otg bcm2708_usb: new USB bus registered, assigned bus number 1
[ 1.929107] dwc_otg bcm2708_usb: irq 32, io mem 0x00000000
[ 1.936102] Init: Port Power? op_state=1
[ 1.941428] Init: Power Port (0)
[ 1.946379] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.954594] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.963246] usb usb1: Product: DWC OTG Controller
[ 1.969399] usb usb1: Manufacturer: Linux 3.12.26+ dwc_otg_hcd
[ 1.976679] usb usb1: SerialNumber: bcm2708_usb
[ 1.983480] hub 1-0:1.0: USB hub found
[ 1.988856] hub 1-0:1.0: 1 port detected
[ 1.994689] dwc_otg: FIQ enabled
[ 1.994710] dwc_otg: NAK holdoff enabled
[ 1.994721] dwc_otg: FIQ split-transaction FSM enabled
[ 1.994742] Module dwc_common_port init
[ 1.995195] usbcore: registered new interface driver usb-storage
[ 2.003151] mousedev: PS/2 mouse device common for all mice
[ 2.010971] bcm2835-cpufreq: min=700000 max=700000 cur=700000
[ 2.018369] bcm2835-cpufreq: switching to governor powersave
[ 2.025498] bcm2835-cpufreq: switching to governor powersave
[ 2.032611] sdhci: Secure Digital Host Controller Interface driver
[ 2.040236] sdhci: Copyright(c) Pierre Ossman
[ 2.046106] sdhci: Enable low-latency mode
[ 2.095506] mmc0: SDHCI controller on BCM2708_Arasan [platform] using platform's DMA
[ 2.106443] mmc0: BCM2708 SDHC host at 0x20300000 DMA 2 IRQ 77
[ 2.113885] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.121201] ledtrig-cpu: registered to indicate activity on CPUs
[ 2.130967] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.145585] usbcore: registered new interface driver usbhid
[ 2.152749] usbhid: USB HID core driver
[ 2.162755] TCP: cubic registered
[ 2.169683] Initializing XFRM netlink socket
[ 2.177555] NET: Registered protocol family 17
[ 2.183690] Key type dns_resolver registered
[ 2.192916] Indeed it is in host mode hprt0 = 00021501
[ 2.204006] registered taskstats version 1
[ 2.226176] Waiting for root device /dev/mmcblk0p2...
[ 2.308097] mmc0: read SD Status register (SSR) after 5 attempts
[ 2.321106] mmc0: new high speed SDHC card at address b368
[ 2.328881] mmcblk0: mmc0:b368 SDC 14.9 GiB
[ 2.336555] mmcblk0: p1 p2
[ 2.425580] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 2.433714] Indeed it is in host mode hprt0 = 00001101
[ 2.472107] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 2.495530] VFS: Mounted root (ext4 filesystem) on device 179:2.
[ 2.515620] devtmpfs: mounted
[ 2.520592] Freeing unused kernel memory: 144K (c060e000 - c0632000)
[ 2.676125] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[ 2.688095] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.697983] hub 1-1:1.0: USB hub found
[ 2.703922] hub 1-1:1.0: 5 ports detected
[ 2.985783] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 3.106179] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 3.114699] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.134038] smsc95xx v1.0.4
[ 3.200256] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-bcm2708_usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:74:10:63
[ 3.325776] usb 1-1.3: new high-speed USB device number 4 using dwc_otg
[ 3.457339] usb 1-1.3: New USB device found, idVendor=0bda, idProduct=8176
[ 3.466122] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 3.478063] usb 1-1.3: Manufacturer: Realtek
[ 3.484062] usb 1-1.3: SerialNumber: 00e04c000001
[ 4.108478] udevd[156]: starting version 175
[ 5.158643] Adafruit Industries' Raspberry Pi PWM driver v1.0
[ 6.338894] bcm2708-i2s bcm2708-i2s.0: Failed to create debugfs directory
[ 7.661639] usbcore: registered new interface driver rtl8192cu
[ 11.389151] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 11.977961] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 12.815862] bcm2708_spi bcm2708_spi.0: master is unqueued, this is deprecated
[ 12.825833] bcm2708_spi bcm2708_spi.0: SPI Controller at 0x20204000 (irq 80)
[ 12.994292] bcm2708_i2c_init_pinmode(0,0)
[ 13.002360] bcm2708_i2c_init_pinmode(0,1)
[ 13.011100] bcm2708_i2c bcm2708_i2c.0: BSC0 Controller at 0x20205000 (irq 79) (baudrate 100000)
[ 13.023313] bcm2708_i2c_init_pinmode(1,2)
[ 13.029062] bcm2708_i2c_init_pinmode(1,3)
[ 13.038042] bcm2708_i2c bcm2708_i2c.1: BSC1 Controller at 0x20804000 (irq 79) (baudrate 100000)
[ 13.202465] fbtft_device: SPI devices registered:
[ 13.219818] fbtft_device: spidev spi0.0 500kHz 8 bits mode=0x00
[ 13.235601] fbtft_device: spidev spi0.1 500kHz 8 bits mode=0x00
[ 13.243562] fbtft_device: 'fb' Platform devices registered:
[ 13.251228] fbtft_device: bcm2708_fb id=-1 pdata? no
[ 13.258321] fbtft_device: I2C devices registered:
[ 13.264636] fbtft_device: i2c-0 addr 48919 IRQ 0
[ 13.271545] fbtft_device: i2c-1 addr 48919 IRQ 1
[ 13.278442] fbtft_device: pcm5122 1-004d addr 77 IRQ 0
[ 13.285751] fbtft_device: wm8804 1-003b addr 59 IRQ 0
[ 13.292869] fbtft_device: pcm5122 1-004c addr 76 IRQ 0
[ 13.375724] fbtft_device: Deleting spi0.0 (spi0.0)
[ 13.396128] fbtft_device: GPIOS used by 'adafruitct28':
[ 13.402953] fbtft_device: 'dc' = GPIO25
[ 13.412996] fbtft_device: SPI devices registered:
[ 13.425194] fbtft_device: spidev spi0.1 500kHz 8 bits mode=0x00
[ 13.442929] fbtft_device: fb_ili9340 spi0.0 32000kHz 8 bits mode=0x00
[ 13.456095] input: ft6x06_ts as /devices/virtual/input/input0
[ 13.463548] fbtft_device: I2C devices registered:
[ 13.474807] fbtft_device: i2c-0 addr 48919 IRQ 0
[ 13.486877] fbtft_device: i2c-1 addr 48919 IRQ 1
[ 13.493663] fbtft_device: pcm5122 1-004d addr 77 IRQ 0
[ 13.506436] fbtft_device: wm8804 1-003b addr 59 IRQ 0
[ 13.517888] fbtft_device: pcm5122 1-004c addr 76 IRQ 0
[ 13.525056] fbtft_device: ft6x06_ts 1-0038 addr 56 IRQ 0
[ 13.665882] i2c-core: driver [ft6x06_ts] using legacy suspend method
[ 13.673658] i2c-core: driver [ft6x06_ts] using legacy resume method
[ 13.689938] Adafruit Industries' power switch driver v1.7
[ 14.268896] graphics fb1: fb_ili9340 frame buffer, 320x240, 150 KiB video memory, 4 KiB DMA buffer memory, fps=20, spi0.0 at 32 MHz
[ 19.800783] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 23.524027] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 39.049044] Adding 102396k swap on /var/swap. Priority:-1 extents:2 across:2134012k SSFS
[ 41.588339] ttyAMA0: 1 input overrun(s)
[ 364.010461] ft6x06_ts 1-0038: ft6x06_read_touchdata read touchdata failed.
[ 364.016468] ft6x06_ts 1-0038: ft6x06_read_touchdata read touchdata failed.
[ 364.027128] ft6x06_ts 1-0038: ft6x06_read_touchdata read touchdata failed.
eta: I double-checked my revision and it looks fine:
pi@raspberrypi ~ $ cat /proc/cpuinfo
processor : 0
model name : ARMv6-compatible processor rev 7 (v6l)
Features : swp half thumb fastmult vfp edsp java tls
CPU implementer : 0x41
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xb76
CPU revision : 7
Hardware : BCM2708
Revision : 000e
Serial : 00000000f6741063
