2.8" 320x240 TFT w/ touchscreen for Pi is Blank White
- jigawatt
I went through all the steps getting the correct OS with TFT capabilities and I can't get anything to show up but an all white screen. I first tried this with the Model B Pi. I have since given away for a christmas present (which went over well). I now have the B+ and havent tried it on this Pi. Is it able to work on the B+ model? If so, can you send me a link the OS that has the TFT touchscreen capabilities already installed? I would upload a picture of the screen all white but as i said I already gave that Pi away. However i did post a pic of my soldering.
- 20150123_181738.jpg (289.52 KiB) Viewed 1368 times
- Franklin97355
Re: 2.8" 320x240 TFT w/ touchscreen for Pi is Blank White
It works on the B+ and you can get the PiTFT image in the learn.adafruit.com section. Do you have the resistive or capacitive touchscreen (what's the product number)
- jigawatt
stmpe610 + ili9341 v2
- jigawatt
OK, so i have SDFormatter and Win32DiskImager. I downloaded this image PiTFT28R-140909-140918. Formatted my 8gig SD card with SDFormatter. Wrote the image with Win32DiskImager and the run. Screen starts off white, then goes dark(but not off, backlight still on), then back to white. Thoughts?
- jigawatt
What's going on here???
- Franklin97355
Could you post the output of dmesg and could you post a picture of the connection on the back?
- jigawatt
When I type this in:
pi@raspberrypi ~ $ sudo mv /usr/share/X11/xorg.conf.d/99-fbturbo.conf ~
I get this:
mv: cannot stat `/usr/share/X11/xorg.conf.d/99-fbturbo.conf': No such file or directory
DMESG:
I get this:
DMESG:
pi@raspberrypi ~ $ dmesg
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 3.18.8+ (root@vagrant-ubuntu-precise-32) (gcc version 4.7.1 20120402 (prerelease) (crosstool-NG 1.15.2) ) #2 PREEMPT Mon Mar 9 14:05:46 UTC 2015
[ 0.000000] CPU: ARMv6-compatible processor [410fb767] revision 7 (ARMv7), cr=00c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
[ 0.000000] Machine model: Raspberry Pi Model B Plus
[ 0.000000] cma: Reserved 8 MiB at 0x1b800000
[ 0.000000] Memory policy: Data cache writeback
[ 0.000000] On node 0 totalpages: 114688
[ 0.000000] free_area_init_node: node 0, pgdat c084db0c, node_mem_map db474000
[ 0.000000] Normal zone: 896 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 114688 pages, LIFO batch:31
[ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 113792
[ 0.000000] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708.boardrev=0x10 bcm2708.serial=0xa2cbfb1d smsc95xx.macaddr=B8:27:EB:CB:FB:1D bcm2708_fb.fbswap=1 bcm2708.disk_led_gpio=47 bcm2708.disk_led_active_low=0 sdhci-bcm2708.emmc_clock_freq=250000000 vc_mem.mem_base=0x1ec00000 vc_mem.mem_size=0x20000000 dwc_otg.lpm_enable=0 console=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline rootwait fbcon=map:10 fbcon=font:VGA8x8
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Memory: 437204K/458752K available (5907K kernel code, 358K rwdata, 1892K rodata, 344K init, 734K bss, 21548K reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xffe00000 (2048 kB)
[ 0.000000] vmalloc : 0xdc800000 - 0xff000000 ( 552 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xdc000000 ( 448 MB)
[ 0.000000] modules : 0xbf000000 - 0xc0000000 ( 16 MB)
[ 0.000000] .text : 0xc0008000 - 0xc07a5e5c (7800 kB)
[ 0.000000] .init : 0xc07a6000 - 0xc07fc000 ( 344 kB)
[ 0.000000] .data : 0xc07fc000 - 0xc0855ba4 ( 359 kB)
[ 0.000000] .bss : 0xc0855ba4 - 0xc090d698 ( 735 kB)
[ 0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] NR_IRQS:522
[ 0.000025] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483648000ns
[ 0.000075] Switching to timer-based delay loop, resolution 1000ns
[ 0.000366] Console: colour dummy device 80x30
[ 0.001701] console [tty1] enabled
[ 0.001752] Calibrating delay loop (skipped), value calculated using timer frequency.. 2.00 BogoMIPS (lpj=10000)
[ 0.001836] pid_max: default: 32768 minimum: 301
[ 0.002227] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.002302] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.003338] Initializing cgroup subsys memory
[ 0.003434] Initializing cgroup subsys devices
[ 0.003498] Initializing cgroup subsys freezer
[ 0.003557] Initializing cgroup subsys net_cls
[ 0.003614] Initializing cgroup subsys blkio
[ 0.003739] CPU: Testing write buffer coherency: ok
[ 0.003857] ftrace: allocating 19717 entries in 58 pages
[ 0.109866] Setting up static identity map for 0x5564c8 - 0x556524
[ 0.112737] devtmpfs: initialized
[ 0.130009] VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
[ 0.133240] pinctrl core: initialized pinctrl subsystem
[ 0.136357] NET: Registered protocol family 16
[ 0.142005] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[ 0.169648] cpuidle: using governor ladder
[ 0.199711] cpuidle: using governor menu
[ 0.200363] bcm2708.uart_clock = 3000000
[ 0.204090] No ATAGs?
[ 0.204156] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
[ 0.204227] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.204296] mailbox: Broadcom VideoCore Mailbox driver
[ 0.204465] bcm2708_vcio: mailbox at f200b880
[ 0.204954] bcm_power: Broadcom power driver
[ 0.205016] bcm_power_open() -> 0
[ 0.205050] bcm_power_request(0, 8)
[ 0.705766] bcm_mailbox_read -> 00000080, 0
[ 0.705815] bcm_power_request -> 0
[ 0.706013] Serial: AMBA PL011 UART driver
[ 0.706258] dev:f1: ttyAMA0 at MMIO 0x20201000 (irq = 83, base_baud = 0) is a PL011 rev3
[ 1.101345] console [ttyAMA0] enabled
[ 1.174808] SCSI subsystem initialized
[ 1.178911] usbcore: registered new interface driver usbfs
[ 1.184705] usbcore: registered new interface driver hub
[ 1.190205] usbcore: registered new device driver usb
[ 1.197488] Switched to clocksource stc
[ 1.228867] FS-Cache: Loaded
[ 1.232186] CacheFiles: Loaded
[ 1.252408] NET: Registered protocol family 2
[ 1.258420] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[ 1.265606] TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
[ 1.272372] TCP: Hash tables configured (established 4096 bind 4096)
[ 1.278909] TCP: reno registered
[ 1.282187] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 1.288126] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 1.294794] NET: Registered protocol family 1
[ 1.299905] RPC: Registered named UNIX socket transport module.
[ 1.305882] RPC: Registered udp transport module.
[ 1.310728] RPC: Registered tcp transport module.
[ 1.315464] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.323262] hw perfevents: enabled with armv6_1176 PMU driver, 3 counters available
[ 1.331415] bcm2708_dma: DMA manager at f2007000
[ 1.336264] vc-mem: phys_addr:0x00000000 mem_base=0x1ec00000 mem_size:0x20000000(512 MiB)
[ 1.346192] futex hash table entries: 256 (order: -1, 3072 bytes)
[ 1.352701] audit: initializing netlink subsys (disabled)
[ 1.358287] audit: type=2000 audit(1.110:1): initialized
[ 1.378829] VFS: Disk quotas dquot_6.5.2
[ 1.383184] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 1.392723] FS-Cache: Netfs 'nfs' registered for caching
[ 1.399874] NFS: Registering the id_resolver key type
[ 1.405050] Key type id_resolver registered
[ 1.409403] Key type id_legacy registered
[ 1.414735] msgmni has been set to 869
[ 1.421145] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ 1.429173] io scheduler noop registered
[ 1.433158] io scheduler deadline registered (default)
[ 1.438901] io scheduler cfq registered
[ 1.445288] BCM2708FB: allocated DMA memory 5bc00000
[ 1.450608] BCM2708FB: allocated DMA channel 0 @ f2007000
[ 1.461500] Console: switching to colour frame buffer device 82x52
[ 1.471984] bcm2708-dmaengine bcm2708-dmaengine: Load BCM2835 DMA engine driver
[ 1.480050] uart-pl011 dev:f1: no DMA platform data
[ 1.485827] vc-cma: Videocore CMA driver
[ 1.489995] vc-cma: vc_cma_base = 0x00000000
[ 1.494782] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
[ 1.500356] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
[ 1.519222] brd: module loaded
[ 1.529600] loop: module loaded
[ 1.533313] vchiq: vchiq_init_state: slot_zero = 0xdb800000, is_master = 0
[ 1.541224] Loading iSCSI transport class v2.0-870.
[ 1.547841] usbcore: registered new interface driver smsc95xx
[ 1.553993] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.762048] Core Release: 2.80a
[ 1.767061] Setting default values for core params
[ 1.773795] Finished setting default values for core params
[ 1.981492] Using Buffer DMA mode
[ 1.986670] Periodic Transfer Interrupt Enhancement - disabled
[ 1.994406] Multiprocessor Interrupt Enhancement - disabled
[ 2.001890] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 2.008147] Dedicated Tx FIFOs mode
[ 2.013902] WARN::dwc_otg_hcd_init:1047: FIQ DMA bounce buffers: virt = 0xdbc14000 dma = 0x5bc14000 len=9024
[ 2.027522] FIQ FSM acceleration enabled for :
[ 2.027522] Non-periodic Split Transactions
[ 2.027522] Periodic Split Transactions
[ 2.027522] High-Speed Isochronous Endpoints
[ 2.051253] dwc_otg: Microframe scheduler enabled
[ 2.051365] WARN::hcd_init_fiq:412: FIQ on core 0 at 0xc03f9518
[ 2.059105] WARN::hcd_init_fiq:413: FIQ ASM at 0xc03f97c8 length 36
[ 2.067142] WARN::hcd_init_fiq:438: MPHI regs_base at 0xdc806000
[ 2.075064] dwc_otg bcm2708_usb: DWC OTG Controller
[ 2.081834] dwc_otg bcm2708_usb: new USB bus registered, assigned bus number 1
[ 2.090971] dwc_otg bcm2708_usb: irq 32, io mem 0x00000000
[ 2.098333] Init: Port Power? op_state=1
[ 2.104033] Init: Power Port (0)
[ 2.109390] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.118037] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.127031] usb usb1: Product: DWC OTG Controller
[ 2.133524] usb usb1: Manufacturer: Linux 3.18.8+ dwc_otg_hcd
[ 2.141097] usb usb1: SerialNumber: bcm2708_usb
[ 2.148601] hub 1-0:1.0: USB hub found
[ 2.154283] hub 1-0:1.0: 1 port detected
[ 2.160761] dwc_otg: FIQ enabled
[ 2.160784] dwc_otg: NAK holdoff enabled
[ 2.160796] dwc_otg: FIQ split-transaction FSM enabled
[ 2.160872] Module dwc_common_port init
[ 2.161474] usbcore: registered new interface driver usb-storage
[ 2.169977] mousedev: PS/2 mouse device common for all mice
[ 2.178411] bcm2835-cpufreq: min=700000 max=700000
[ 2.185420] sdhci: Secure Digital Host Controller Interface driver
[ 2.193552] sdhci: Copyright(c) Pierre Ossman
[ 2.200122] DMA channels allocated for the MMC driver
[ 2.237565] Load BCM2835 MMC driver
[ 2.245148] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.260330] ledtrig-cpu: registered to indicate activity on CPUs
[ 2.270869] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.281777] usbcore: registered new interface driver usbhid
[ 2.291402] usbhid: USB HID core driver
[ 2.300984] TCP: cubic registered
[ 2.306245] Initializing XFRM netlink socket
[ 2.312534] NET: Registered protocol family 17
[ 2.319143] Key type dns_resolver registered
[ 2.327037] registered taskstats version 1
[ 2.333402] vc-sm: Videocore shared memory driver
[ 2.340092] [vc_sm_connected_init]: start
[ 2.347166] [vc_sm_connected_init]: end - returning 0
[ 2.355982] Waiting for root device /dev/mmcblk0p2...
[ 2.363383] Indeed it is in host mode hprt0 = 00021501
[ 2.375469] mmc0: host does not support reading read-only switch, assuming write-enable
[ 2.400233] mmc0: new high speed SDHC card at address 0007
[ 2.418238] mmcblk0: mmc0:0007 SD08G 7.42 GiB
[ 2.439186] mmcblk0: p1 p2
[ 2.496103] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 2.508156] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 2.518780] devtmpfs: mounted
[ 2.524818] Freeing unused kernel memory: 344K (c07a6000 - c07fc000)
[ 2.577824] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 2.588967] Indeed it is in host mode hprt0 = 00001101
[ 2.798169] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[ 2.806916] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.819831] hub 1-1:1.0: USB hub found
[ 2.826130] hub 1-1:1.0: 5 ports detected
[ 3.107811] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 3.218285] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 3.227236] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.241943] smsc95xx v1.0.4
[ 3.316364] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-bcm2708_usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:cb:fb:1d
[ 3.587874] usb 1-1.2: new full-speed USB device number 4 using dwc_otg
[ 3.703690] usb 1-1.2: New USB device found, idVendor=05a4, idProduct=1700
[ 3.727728] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.737162] usb 1-1.2: Product: W/L Keyboard/Mouse
[ 3.757703] usb 1-1.2: Manufacturer: ORTEK
[ 3.868004] usb 1-1.4: new high-speed USB device number 5 using dwc_otg
[ 4.006224] usb 1-1.4: New USB device found, idVendor=148f, idProduct=5370
[ 4.022449] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 4.045563] usb 1-1.4: Product: 802.11 n WLAN
[ 4.053099] usb 1-1.4: Manufacturer: Ralink
[ 4.064630] usb 1-1.4: SerialNumber: 1.0
[ 4.363056] udevd[159]: starting version 175
[ 5.792334] input: ORTEK W/L Keyboard/Mouse as /devices/platform/bcm2708_usb/usb1/1-1/1-1.2/1-1.2:1.0/0003:05A4:1700.0001/input/input0
[ 6.040457] ortek 0003:05A4:1700.0001: input,hidraw0: USB HID v1.10 Keyboard [ORTEK W/L Keyboard/Mouse] on usb-bcm2708_usb-1.2/input0
[ 6.197078] GPIO $dc878000 = 0x24800000
[ 6.227964] cfg80211: Calling CRDA to update world regulatory domain
[ 6.274929] GPIO $dc878004 = 0x24024
[ 6.349670] input: ORTEK W/L Keyboard/Mouse as /devices/platform/bcm2708_usb/usb1/1-1/1-1.2/1-1.2:1.1/0003:05A4:1700.0002/input/input1
[ 6.399237] * 0xdc878000 &= ~ 0xE00000
[ 6.405159] * 0xdc878000 | 4 << 0x0015
[ 6.647707] * 0xdc878000 &= ~ 0x7000000
[ 6.653668] * 0xdc878000 | 4 << 0x0018
[ 6.788354] ortek 0003:05A4:1700.0002: input,hidraw1: USB HID v1.10 Mouse [ORTEK W/L Keyboard/Mouse] on usb-bcm2708_usb-1.2/input1
[ 7.004805] * 0xdc878000 &= ~ 0x38000000
[ 7.161652] * 0xdc878000 | 4 << 0x001B
[ 7.355553] * 0xdc878004 &= ~ 0x0007
[ 7.490029] * 0xdc878004 | 4 << 0x0000
[ 7.565106] * 0xdc878004 &= ~ 0x0038
[ 7.578255] usb 1-1.4: reset high-speed USB device number 5 using dwc_otg
[ 7.647692] * 0xdc878004 | 4 << 0x0003
[ 7.653546] GPIO $dc878000 = 0x24800000
[ 7.779919] ieee80211 phy0: rt2x00_set_rt: Info - RT chipset 5390, rev 0502 detected
[ 7.809094] GPIO $dc878004 = 0x24024
[ 7.886722] bcm2708_spi 20204000.spi: DMA channel 2 at address 0xf2007200 with irq 77
[ 8.026671] bcm2708_spi 20204000.spi: DMA channel 4 at address 0xf2007400 with irq 20
[ 8.057101] random: nonblocking pool is initialized
[ 8.164995] stmpe-spi spi0.1: stmpe610 detected, chip id: 0x811
[ 8.233516] ieee80211 phy0: rt2x00_set_rf: Info - RF chipset 5370 detected
[ 8.266086] fb_ili9340: module is from the staging directory, the quality is unknown, you have been warned.
[ 8.298803] fbtft_of_value: buswidth = 8
[ 8.304902] fbtft_of_value: debug = 0
[ 8.371208] fbtft_of_value: rotate = 90
[ 8.377221] fbtft_of_value: fps = 20
[ 8.396438] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
[ 8.398863] usbcore: registered new interface driver rt2800usb
[ 9.270702] graphics fb1: fb_ili9340 frame buffer, 320x240, 150 KiB video memory, 4 KiB DMA buffer memory, fps=20, spi0.0 at 32 MHz
[ 9.305706] bcm2708_spi 20204000.spi: SPI Controller at 0x20204000 (irq 80)
[ 9.326840] bcm2708_spi 20204000.spi: SPI Controller running in dma mode
[ 9.343325] bcm2708_i2c_init_pinmode(1,2)
[ 9.369297] bcm2708_i2c_init_pinmode(1,3)
[ 9.392845] bcm2708_i2c 20804000.i2c: BSC1 Controller at 0x20804000 (irq 79) (baudrate 100000)
[ 12.493779] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 13.830322] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 14.931639] input: stmpe-ts as /devices/soc/20204000.spi/spi_master/spi0/spi0.1/stmpe-ts/input/input2
[ 15.136249] Adafruit Industries' power switch driver v1.7
[ 24.864444] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 24.910024] ieee80211 phy0: rt2x00lib_request_firmware: Info - Loading firmware file 'rt2870.bin'
[ 24.917675] ieee80211 phy0: rt2x00lib_request_firmware: Info - Firmware detected - version: 0.29
[ 29.204274] wlan0: authenticate with a4:7a:a4:24:21:e0
[ 29.278326] wlan0: send auth to a4:7a:a4:24:21:e0 (try 1/3)
[ 29.280142] wlan0: authenticated
[ 29.281812] rt2800usb 1-1.4:1.0 wlan0: disabling HT/VHT due to WEP/TKIP use
[ 29.288138] wlan0: associate with a4:7a:a4:24:21:e0 (try 1/3)
[ 29.291202] wlan0: RX AssocResp from a4:7a:a4:24:21:e0 (capab=0x411 status=0 aid=6)
[ 29.301952] wlan0: associated
[ 34.415829] Adding 102396k swap on /var/swap. Priority:-1 extents:2 across:2134012k SSFS
- Franklin97355
Does this file actually exist? /usr/share/X11/xorg.conf.d/99-fbturbo.conf' Have you tried the latest version from this page? https://learn.adafruit.com/adafruit-2-8 ... sy-install
- jigawatt
No, not that version yet. The other "easy install" wasnt so easy for me for some reason. I'll give it a try and repost. thanks
- jigawatt
So I tried the PiTFT image. It appears not to be working. My screen turns white when power is applied to Pi. After a few seconds the white pixels turn off while the backlight stays on. Then nothing. I feel I tried everything, from latest PiTFT images to installing from standard Rasbian image.
- adafruit2
could easily be soldering, please try to resolder the connector, also check that the TFT is installed right!
https://learn.adafruit.com/adafruit-pit ... faq#faq-12
- jigawatt
I've re-touched/soldered all vias/pins. Still nothing. At this point I'd like to send back the screen and get a new one. I've had this thing for almost 6 months and I would like to use it. I tried everything and I keep running into issues and I think its due to something out of my control..
- jigawatt
- jigawatt
Here's some more pics...
- back_tft_3.jpg (272.92 KiB) Viewed 954 times
- back_tft_2.jpg (303.57 KiB) Viewed 954 times
- back_tft_1.jpg (373.17 KiB) Viewed 954 times
- jigawatt
3 more
- back_tft_6.jpg (274.7 KiB) Viewed 954 times
- back_tft_5.jpg (293.95 KiB) Viewed 954 times
- back_tft_4.jpg (301.52 KiB) Viewed 954 times
