I recently purchased the Adafruit 5" touch screen display for a Raspberry Pi project I'm working on. Today I hooked everything up. The LEDs are responsive and indicate everything is working except I'm left with a blank screen.
I have spent the past few hours searching through information online trying to figure out what the issue is. I was under the impression it was plug n play. I tried adding a couple of lines to the config.txt file of the OpenElec Operating System but no luck with that either.
I can't figure out if there is an extra step I need to take to make the screen display work? The screen came with no manual or setup instructions which is not helpful.
Help would be very much appreciated.
LCD screen has no video output (blank screen)
- brooke89
- Franklin97355
Re: LCD screen has no video output (blank screen)
Which screen did you purchase? There are several models
- brooke89
HDMI 4 PI: 5" DISPLAY W/TOUCH AND MINI DRIVER - 800X480 HDMI
- brooke89
Bump, please help. This is stalling a project which has been so much fun before this issue. Would really like to figure out what the problem is.
- Franklin97355
Have you followed the instructions here? https://learn.adafruit.com/hdmi-ubergui ... er-800x480 Post some pictures of your set up.
- brooke89
Yes I have. Here are some pictures...franklin97355 wrote:Have you followed the instructions here? https://learn.adafruit.com/hdmi-ubergui ... er-800x480 Post some pictures of your set up.
Edit
The led on the board with buttons for the screen is green but then constantly blinks red, goes back and forth.
- adafruit2
try powering the display redblack USB cable from a wall adapter or other not-pi - the Pi may not be able to provide power for the display thru USB! at least then you'll know if it works :)
- brooke89
That's weird, I edited that previous post, but the edit is reverted now. I figured that out in the end, it was hooked up wrong. Then I got AV1 and a no display message. Then after reading some posts on here, I figured out how to switch from AV1 to HDMI input. Then hooray, the screen finally worked! But now the touch screen isn't working. I am hoping that when I change the screen resolution that the touch screen will work... will post when I find out :)
