2.8 tft raspberry pi not working
ee495
Post by ee495 »
I have a 2.8' tft (pid:1601) for the raspberry pi b+ that is no longer working. I followed the easy install steps
on the website and i am using a raspian operating system. The screen will go from white to black on start up but
will not show anything.
Heres the results from dmesg
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Initializing cgroup subsys cpu
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 3.12.26+ (ladyada@ladyada-VirtualBox) (gcc version 4.4.7 (Ubuntu/Linaro 4.4.7-1ubuntu2) ) #7 PREEMPT Wed Sep 17 14:25:24 EDT 2014
[    0.000000] CPU: ARMv6-compatible processor [410fb767] revision 7 (ARMv7), cr=00c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
[    0.000000] Machine: BCM2708
[    0.000000] cma: CMA: reserved 8 MiB at 1b800000
[    0.000000] Memory policy: ECC disabled, Data cache writeback
[    0.000000] On node 0 totalpages: 114688
[    0.000000] free_area_init_node: node 0, pgdat c0670468, node_mem_map c0721000
[    0.000000]   Normal zone: 896 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 114688 pages, LIFO batch:31
[    0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[    0.000000] pcpu-alloc: [0] 0
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 113792
[    0.000000] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708.boardrev=0x10 bcm2708.serial=0x32bacda4 smsc95xx.macaddr=B8:27:EB:BA:CD:A4 bcm2708.disk_led_gpio=47 bcm2708.disk_led_active_low=0 sdhci-bcm2708.emmc_clock_freq=250000000 vc_mem.mem_base=0x1ec00000 vc_mem.mem_size=0x20000000  dwc_otg.lpm_enable=0 console=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline rootwait fbcon=map:10 fbcon=font:VGA8x8
[    0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.000000] Memory: 439204K/458752K available (4815K kernel code, 243K rwdata, 1352K rodata, 146K init, 701K bss, 19548K reserved)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
[    0.000000]     vmalloc : 0xdc800000 - 0xff000000   ( 552 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xdc000000   ( 448 MB)
[    0.000000]     modules : 0xbf000000 - 0xc0000000   (  16 MB)
[    0.000000]       .text : 0xc0008000 - 0xc060dee4   (6168 kB)
[    0.000000]       .init : 0xc060e000 - 0xc0632a44   ( 147 kB)
[    0.000000]       .data : 0xc0634000 - 0xc0670d60   ( 244 kB)
[    0.000000]        .bss : 0xc0670d6c - 0xc0720228   ( 702 kB)
[    0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000] NR_IRQS:394
[    0.000000] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 4294967ms
[    0.000000] Switching to timer-based delay loop
[    0.000000] Console: colour dummy device 80x30
[    0.000000] console [tty1] enabled
[    0.001281] Calibrating delay loop (skipped), value calculated using timer frequency.. 2.00 BogoMIPS (lpj=10000)
[    0.001346] pid_max: default: 32768 minimum: 301
[    0.001803] Mount-cache hash table entries: 512
[    0.002610] Initializing cgroup subsys memory
[    0.002723] Initializing cgroup subsys devices
[    0.002763] Initializing cgroup subsys freezer
[    0.002797] Initializing cgroup subsys blkio
[    0.002936] CPU: Testing write buffer coherency: ok
[    0.003429] Setting up static identity map for 0xc04965e0 - 0xc049663c
[    0.005363] devtmpfs: initialized
[    0.021585] VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
[    0.023222] NET: Registered protocol family 16
[    0.028631] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[    0.029347] cpuidle: using governor ladder
[    0.029400] cpuidle: using governor menu
[    0.029862] bcm2708.uart_clock = 0
[    0.031945] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
[    0.032010] hw-breakpoint: maximum watchpoint size is 4 bytes.
[    0.032048] mailbox: Broadcom VideoCore Mailbox driver
[    0.032149] bcm2708_vcio: mailbox at f200b880
[    0.032263] bcm_power: Broadcom power driver
[    0.032305] bcm_power_open() -> 0
[    0.032333] bcm_power_request(0, 8)
[    0.533055] bcm_mailbox_read -> 00000080, 0
[    0.533097] bcm_power_request -> 0
[    0.533303] Serial: AMBA PL011 UART driver
[    0.533493] dev:f1: ttyAMA0 at MMIO 0x20201000 (irq = 83, base_baud = 0) is a PL011 rev3
[    0.895956] console [ttyAMA0] enabled
[    0.922630] bio: create slab <bio-0> at 0
[    0.928368] SCSI subsystem initialized
[    0.932401] usbcore: registered new interface driver usbfs
[    0.938122] usbcore: registered new interface driver hub
[    0.943709] usbcore: registered new device driver usb
[    0.950366] Switched to clocksource stc
[    0.954634] FS-Cache: Loaded
[    0.957807] CacheFiles: Loaded
[    0.974011] NET: Registered protocol family 2
[    0.979493] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
[    0.986930] TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
[    0.993509] TCP: Hash tables configured (established 4096 bind 4096)
[    0.999964] TCP: reno registered
[    1.003264] UDP hash table entries: 256 (order: 0, 4096 bytes)
[    1.009138] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[    1.015858] NET: Registered protocol family 1
[    1.020884] RPC: Registered named UNIX socket transport module.
[    1.026848] RPC: Registered udp transport module.
[    1.031670] RPC: Registered tcp transport module.
[    1.036397] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.043853] bcm2708_dma: DMA manager at f2007000
[    1.048617] bcm2708_gpio: bcm2708_gpio_probe c0641e70
[    1.054175] vc-mem: phys_addr:0x00000000 mem_base=0x1ec00000 mem_size:0x20000000(512 MiB)
[    1.063758] audit: initializing netlink socket (disabled)
[    1.069270] type=2000 audit(0.910:1): initialized
[    1.244952] VFS: Disk quotas dquot_6.5.2
[    1.249226] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    1.258196] FS-Cache: Netfs 'nfs' registered for caching
[    1.265145] NFS: Registering the id_resolver key type
[    1.270318] Key type id_resolver registered
[    1.274648] Key type id_legacy registered
[    1.279397] msgmni has been set to 873
[    1.285242] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[    1.293119] io scheduler noop registered
[    1.297079] io scheduler deadline registered (default)
[    1.302707] io scheduler cfq registered
[    1.307807] BCM2708FB: allocated DMA memory 5bc00000
[    1.313006] BCM2708FB: allocated DMA channel 0 @ f2007000
[    1.322795] Console: switching to colour frame buffer device 82x52
[    1.332030] bcm2708-dmaengine bcm2708-dmaengine: Load BCM2835 DMA engine driver
[    1.339801] uart-pl011 dev:f1: no DMA platform data
[    1.345564] vc-cma: Videocore CMA driver
[    1.349566] vc-cma: vc_cma_base      = 0x00000000
[    1.354446] vc-cma: vc_cma_size      = 0x00000000 (0 MiB)
[    1.359913] vc-cma: vc_cma_initial   = 0x00000000 (0 MiB)
[    1.374927] brd: module loaded
[    1.383350] loop: module loaded
[    1.386843] vchiq: vchiq_init_state: slot_zero = 0xdb800000, is_master = 0
[    1.394864] Loading iSCSI transport class v2.0-870.
[    1.401100] usbcore: registered new interface driver smsc95xx
[    1.407192] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[    1.614741] Core Release: 2.80a
[    1.619353] Setting default values for core params
[    1.625673] Finished setting default values for core params
[    1.832769] Using Buffer DMA mode
[    1.837515] Periodic Transfer Interrupt Enhancement - disabled
[    1.844796] Multiprocessor Interrupt Enhancement - disabled
[    1.851833] OTG VER PARAM: 0, OTG VER FLAG: 0
[    1.857622] Dedicated Tx FIFOs mode
[    1.862994] WARN::dwc_otg_hcd_init:1042: FIQ DMA bounce buffers: virt = 0xdbc14000 dma = 0x5bc14000 len=9024
[    1.875799] FIQ FSM acceleration enabled for :
[    1.875799] Non-periodic Split Transactions
[    1.875799] Periodic Split Transactions
[    1.875799] High-Speed Isochronous Endpoints
[    1.898075] dwc_otg: Microframe scheduler enabled
[    1.898177] WARN::hcd_init:473: FIQ at 0xc0364444
[    1.904356] WARN::hcd_init:474: FIQ ASM at 0xc0364858 length 36
[    1.911816] WARN::hcd_init:500: MPHI regs_base at 0xdc806000
[    1.918886] dwc_otg bcm2708_usb: DWC OTG Controller
[    1.925236] dwc_otg bcm2708_usb: new USB bus registered, assigned bus number 1
[    1.934016] dwc_otg bcm2708_usb: irq 32, io mem 0x00000000
[    1.941001] Init: Port Power? op_state=1
[    1.946326] Init: Power Port (0)
[    1.951271] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    1.959483] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.968137] usb usb1: Product: DWC OTG Controller
[    1.974285] usb usb1: Manufacturer: Linux 3.12.26+ dwc_otg_hcd
[    1.981563] usb usb1: SerialNumber: bcm2708_usb
[    1.988358] hub 1-0:1.0: USB hub found
[    1.993728] hub 1-0:1.0: 1 port detected
[    1.999557] dwc_otg: FIQ enabled
[    1.999578] dwc_otg: NAK holdoff enabled
[    1.999589] dwc_otg: FIQ split-transaction FSM enabled
[    1.999611] Module dwc_common_port init
[    2.000061] usbcore: registered new interface driver usb-storage
[    2.008003] mousedev: PS/2 mouse device common for all mice
[    2.015827] bcm2835-cpufreq: min=700000 max=700000 cur=700000
[    2.023214] bcm2835-cpufreq: switching to governor powersave
[    2.030281] bcm2835-cpufreq: switching to governor powersave
[    2.037429] sdhci: Secure Digital Host Controller Interface driver
[    2.045073] sdhci: Copyright(c) Pierre Ossman
[    2.050946] sdhci: Enable low-latency mode
[    2.100435] mmc0: SDHCI controller on BCM2708_Arasan [platform] using platform's DMA
[    2.111366] mmc0: BCM2708 SDHC host at 0x20300000 DMA 2 IRQ 77
[    2.118821] sdhci-pltfm: SDHCI platform and OF driver helper
[    2.126145] ledtrig-cpu: registered to indicate activity on CPUs
[    2.135911] hidraw: raw HID events driver (C) Jiri Kosina
[    2.150527] usbcore: registered new interface driver usbhid
[    2.157685] usbhid: USB HID core driver
[    2.167700] TCP: cubic registered
[    2.174624] Initializing XFRM netlink socket
[    2.182507] NET: Registered protocol family 17
[    2.188655] Key type dns_resolver registered
[    2.197834] Indeed it is in host mode hprt0 = 00021501
[    2.208967] registered taskstats version 1
[    2.231112] Waiting for root device /dev/mmcblk0p2...
[    2.251062] mmc0: new high speed SDHC card at address 59b4
[    2.270678] mmcblk0: mmc0:59b4 NCard 14.9 GiB
[    2.277947]  mmcblk0: p1 p2
[    2.393933] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    2.405145] VFS: Mounted root (ext4 filesystem) on device 179:2.
[    2.415839] devtmpfs: mounted
[    2.420595] usb 1-1: new high-speed USB device number 2 using dwc_otg
[    2.428722] Indeed it is in host mode hprt0 = 00001101
[    2.435969] Freeing unused kernel memory: 144K (c060e000 - c0632000)
[    2.640945] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[    2.649338] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    2.659448] hub 1-1:1.0: USB hub found
[    2.665049] hub 1-1:1.0: 5 ports detected
[    2.950680] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[    3.061062] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[    3.069575] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    3.089789] smsc95xx v1.0.4
[    3.156530] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-bcm2708_usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:ba:cd:a4
[    3.280649] usb 1-1.2: new high-speed USB device number 4 using dwc_otg
[    3.412568] usb 1-1.2: New USB device found, idVendor=0bda, idProduct=8176
[    3.421688] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    3.430827] usb 1-1.2: Product: 802.11n WLAN Adapter
[    3.438253] usb 1-1.2: Manufacturer: Realtek
[    3.444356] usb 1-1.2: SerialNumber: 00e04c000001
[    4.099975] udevd[156]: starting version 175
[    5.099709] bcm2708_i2c_init_pinmode(0,0)
[    5.116120] Adafruit Industries' Raspberry Pi PWM driver v1.0
[    5.213827] bcm2708_i2c_init_pinmode(0,1)
[    5.219818] bcm2708_i2c bcm2708_i2c.0: BSC0 Controller at 0x20205000 (irq 79) (baudrate 100000)
[    5.484420] bcm2708_spi bcm2708_spi.0: master is unqueued, this is deprecated
[    5.605427] bcm2708_spi bcm2708_spi.0: SPI Controller at 0x20204000 (irq 80)
[    5.755945] bcm2708_i2c_init_pinmode(1,2)
[    5.790596] bcm2708_i2c_init_pinmode(1,3)
[    5.796964] bcm2708_i2c bcm2708_i2c.1: BSC1 Controller at 0x20804000 (irq 79) (baudrate 100000)
[    6.535004] bcm2708-i2s bcm2708-i2s.0: Failed to create debugfs directory
[    7.840701] pcm512x 1-004d: Failed to reset device: -5
[    7.847744] pcm512x: probe of 1-004d failed with error -5
[    7.908728] usbcore: registered new interface driver rtl8192cu
[    7.922976] pcm512x 1-004c: Failed to reset device: -5
[    7.929976] pcm512x: probe of 1-004c failed with error -5
[   10.687831] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[   11.324218] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[   12.316656] fbtft_device:  SPI devices registered:
[   12.330592] fbtft_device:      spidev spi0.0 500kHz 8 bits mode=0x00
[   12.338598] fbtft_device:      spidev spi0.1 500kHz 8 bits mode=0x00
[   12.355858] fbtft_device:  'fb' Platform devices registered:
[   12.363367] fbtft_device:      bcm2708_fb id=-1 pdata? no
[   12.370335] fbtft_device:  I2C devices registered:
[   12.376825] fbtft_device:       i2c-0  addr 48896  IRQ 0
[   12.383766] fbtft_device:       i2c-1  addr 48896  IRQ 1
[   12.390624] fbtft_device:      pcm5122 1-004d  addr 77  IRQ 0
[   12.397825] fbtft_device:      wm8804 1-003b  addr 59  IRQ 0
[   12.404948] fbtft_device:      pcm5122 1-004c  addr 76  IRQ 0
[   12.490547] fbtft_device: Deleting spi0.1 (spi0.1)
[   12.503609] stmpe-spi spi0.1: stmpe610 detected, chip id: 0x811
[   12.528038] fbtft_device: Deleting spi0.0 (spi0.0)
[   12.541059] fbtft_device:  GPIOS used by 'adafruitrt28':
[   12.547836] fbtft_device:    'dc' = GPIO25
[   12.570658] fbtft_device:  SPI devices registered:
[   12.576915] fbtft_device:      stmpe610 spi0.1 500kHz 8 bits mode=0x00
[   12.600563] fbtft_device:      fb_ili9340 spi0.0 32000kHz 8 bits mode=0x00
[   12.691691] input: stmpe-ts as /devices/platform/bcm2708_spi.0/spi_master/spi0/spi0.1/stmpe-ts.0/input/input0
[   13.713359] graphics fb1: fb_ili9340 frame buffer, 320x240, 150 KiB video memory, 4 KiB DMA buffer memory, fps=20, spi0.0 at 32 MHz
[   22.792784] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[   26.701745] bcm2835-cpufreq: switching to governor ondemand
[   26.701781] bcm2835-cpufreq: switching to governor ondemand
[   31.123694] Adding 102396k swap on /var/swap.  Priority:-1 extents:2 across:2134012k SSFS
ee495
Re: 2.8 tft raspberry pi not working
Post by ee495 »
As well when i test the screen using sudo evtest /dev/input/touchscreen, feedback is recorded there just is a black
screen.
