Hello
I have ordered 2 x 2.8" TFT LCD with Cap Touch Breakout Board w/MicroSD Socket[ID:2090] at 05.Feb. My Ordernumber is 699146-9050340820. As I get them I have tested them like it's discripted on the offical Webside( https://learn.adafruit.com/adafruit-2-d ... reakout-v2 ). So one Display was running without any problems. The Second one have a loose connection. So when I press a little with my finger on the upper edge it works. Otherwise it does not. Now I would like to change the Display with the loose connection.
Thanks for a fast reply
Cedric
Return defect TFT LCD
- Franklin97355
Re: Return defect TFT LCD
Could you post clear, detailed pictures of both sides of your board showing any soldering you have done and the connections to it?
- gosow9
some pictures are in the attachment. But I'm pretty sure it have a loose connection at the ribbon cable which connects the displaycontroler to the display. Also the second one works without a problem and one works only if it be pressed a little down so I assume the ribbon cable have contact.
- Attachments
- image3.JPG (154.16 KiB) Viewed 329 times
- image4.JPG (141.51 KiB) Viewed 329 times
- image5.JPG (114.78 KiB) Viewed 329 times
- gosow9
more pictures
- Attachments
- image1.JPG (151.42 KiB) Viewed 329 times
- image2.JPG (146.54 KiB) Viewed 329 times
- adafruit_support_rick
Make sure the 'ears' on the flat flex cable connector are pushed all the way in.
- gosow9
Probably you have to know that I'm in my senior year as electro engineer. So I already know what the issiue is with the Display. But I cant repair it myself because it is under the Display. So I don not want to risk any dammage with taking the Display away from the board. The loose connection is between display and board.
But I have to know where I have to send the display so I get a new one.
Cedric
Cedric
Please email [email protected] with a link to this thread for a replacement display
