I think my 3.5" TFT display is DOA. I tried it using the quick install method on 2 different rPi's, and all I get is a backlit white screen.
I tried it on the latest version of Raspbian, and an older version, but no go. I forget which combination it was, but the rPi wouldn't even boot after the script was installed.
Any ideas? Any eta on a version that works with the newest version of Raspbian? On the Rpi 2 B?
Thanks.
rPi 3.5" TFT DOA
- adafruit_support_rick
Re: rPi 3.5" TFT DOA
Please post the output of sudo dmesg
Post a clear picture of the bottom of the display board.
- googly_eyes
Sorry, that is the best I could do for the photo
pi@raspberrypi ~ $ sudo dmesg
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 3.12.26+ (ladyada@ladyada-VirtualBox) (gcc version 4.4.7 (Ubuntu/Linaro 4.4.7-1ubuntu2) ) #7 PREEMPT Wed Sep 17 14:25:24 EDT 2014
[ 0.000000] CPU: ARMv6-compatible processor [410fb767] revision 7 (ARMv7), cr=00c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
[ 0.000000] Machine: BCM2708
[ 0.000000] cma: CMA: reserved 8 MiB at 0b800000
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] On node 0 totalpages: 49152
[ 0.000000] free_area_init_node: node 0, pgdat c0670468, node_mem_map c0721000
[ 0.000000] Normal zone: 384 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 49152 pages, LIFO batch:15
[ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 48768
[ 0.000000] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708.boardrev=0x2 bcm2708.serial=0xa0df5918 smsc95xx.macaddr=B8:27:EB:DF:59:18 sdhci-bcm2708.emmc_clock_freq=250000000 vc_mem.mem_base=0xec00000 vc_mem.mem_size=0x10000000 dwc_otg.lpm_enable=0 console=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline rootwait fbcon=map:10 fbcon=font:VGA8x8
[ 0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] Memory: 179308K/196608K available (4815K kernel code, 243K rwdata, 1352K rodata, 146K init, 701K bss, 17300K reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] vmalloc : 0xcc800000 - 0xff000000 ( 808 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xcc000000 ( 192 MB)
[ 0.000000] modules : 0xbf000000 - 0xc0000000 ( 16 MB)
[ 0.000000] .text : 0xc0008000 - 0xc060dee4 (6168 kB)
[ 0.000000] .init : 0xc060e000 - 0xc0632a44 ( 147 kB)
[ 0.000000] .data : 0xc0634000 - 0xc0670d60 ( 244 kB)
[ 0.000000] .bss : 0xc0670d6c - 0xc0720228 ( 702 kB)
[ 0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] NR_IRQS:394
[ 0.000000] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 4294967ms
[ 0.000000] Switching to timer-based delay loop
[ 0.000000] Console: colour dummy device 80x30
[ 0.000000] console [tty1] enabled
[ 0.001254] Calibrating delay loop (skipped), value calculated using timer frequency.. 2.00 BogoMIPS (lpj=10000)
[ 0.001319] pid_max: default: 32768 minimum: 301
[ 0.001763] Mount-cache hash table entries: 512
[ 0.002550] Initializing cgroup subsys memory
[ 0.002660] Initializing cgroup subsys devices
[ 0.002701] Initializing cgroup subsys freezer
[ 0.002737] Initializing cgroup subsys blkio
[ 0.002873] CPU: Testing write buffer coherency: ok
[ 0.003388] Setting up static identity map for 0xc04965e0 - 0xc049663c
[ 0.005304] devtmpfs: initialized
[ 0.021544] VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
[ 0.023167] NET: Registered protocol family 16
[ 0.028483] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[ 0.029184] cpuidle: using governor ladder
[ 0.029234] cpuidle: using governor menu
[ 0.029682] bcm2708.uart_clock = 0
[ 0.031756] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
[ 0.031821] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.031859] mailbox: Broadcom VideoCore Mailbox driver
[ 0.031962] bcm2708_vcio: mailbox at f200b880
[ 0.032077] bcm_power: Broadcom power driver
[ 0.032118] bcm_power_open() -> 0
[ 0.032144] bcm_power_request(0, 8)
[ 0.532867] bcm_mailbox_read -> 00000080, 0
[ 0.532912] bcm_power_request -> 0
[ 0.533113] Serial: AMBA PL011 UART driver
[ 0.533308] dev:f1: ttyAMA0 at MMIO 0x20201000 (irq = 83, base_baud = 0) is a PL011 rev3
[ 0.890660] console [ttyAMA0] enabled
[ 0.917330] bio: create slab <bio-0> at 0
[ 0.923084] SCSI subsystem initialized
[ 0.927101] usbcore: registered new interface driver usbfs
[ 0.932826] usbcore: registered new interface driver hub
[ 0.938410] usbcore: registered new device driver usb
[ 0.945063] Switched to clocksource stc
[ 0.949300] FS-Cache: Loaded
[ 0.952470] CacheFiles: Loaded
[ 0.968747] NET: Registered protocol family 2
[ 0.974225] TCP established hash table entries: 2048 (order: 2, 16384 bytes)
[ 0.981599] TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.988069] TCP: Hash tables configured (established 2048 bind 2048)
[ 0.994523] TCP: reno registered
[ 0.997825] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 1.003700] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 1.010427] NET: Registered protocol family 1
[ 1.015453] RPC: Registered named UNIX socket transport module.
[ 1.021415] RPC: Registered udp transport module.
[ 1.026234] RPC: Registered tcp transport module.
[ 1.030961] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.038415] bcm2708_dma: DMA manager at f2007000
[ 1.043180] bcm2708_gpio: bcm2708_gpio_probe c0641e70
[ 1.048729] vc-mem: phys_addr:0x00000000 mem_base=0x0ec00000 mem_size:0x10000000(256 MiB)
[ 1.058302] audit: initializing netlink socket (disabled)
[ 1.063810] type=2000 audit(0.910:1): initialized
[ 1.238582] VFS: Disk quotas dquot_6.5.2
[ 1.242856] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 1.251798] FS-Cache: Netfs 'nfs' registered for caching
[ 1.258760] NFS: Registering the id_resolver key type
[ 1.263979] Key type id_resolver registered
[ 1.268311] Key type id_legacy registered
[ 1.273057] msgmni has been set to 366
[ 1.278892] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ 1.286758] io scheduler noop registered
[ 1.290719] io scheduler deadline registered (default)
[ 1.296359] io scheduler cfq registered
[ 1.301431] BCM2708FB: allocated DMA memory 4bc00000
[ 1.306632] BCM2708FB: allocated DMA channel 0 @ f2007000
[ 1.316444] Console: switching to colour frame buffer device 82x52
[ 1.325715] bcm2708-dmaengine bcm2708-dmaengine: Load BCM2835 DMA engine driver
[ 1.333489] uart-pl011 dev:f1: no DMA platform data
[ 1.339253] vc-cma: Videocore CMA driver
[ 1.343254] vc-cma: vc_cma_base = 0x00000000
[ 1.348131] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
[ 1.353599] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
[ 1.368655] brd: module loaded
[ 1.377072] loop: module loaded
[ 1.380559] vchiq: vchiq_init_state: slot_zero = 0xcb800000, is_master = 0
[ 1.388578] Loading iSCSI transport class v2.0-870.
[ 1.394709] usbcore: registered new interface driver smsc95xx
[ 1.400876] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.608415] Core Release: 2.80a
[ 1.613039] Setting default values for core params
[ 1.619368] Finished setting default values for core params
[ 1.826476] Using Buffer DMA mode
[ 1.831236] Periodic Transfer Interrupt Enhancement - disabled
[ 1.838525] Multiprocessor Interrupt Enhancement - disabled
[ 1.845574] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 1.851379] Dedicated Tx FIFOs mode
[ 1.856722] WARN::dwc_otg_hcd_init:1042: FIQ DMA bounce buffers: virt = 0xcbc14000 dma = 0x4bc14000 len=9024
[ 1.869545] FIQ FSM acceleration enabled for :
[ 1.869545] Non-periodic Split Transactions
[ 1.869545] Periodic Split Transactions
[ 1.869545] High-Speed Isochronous Endpoints
[ 1.891846] dwc_otg: Microframe scheduler enabled
[ 1.891946] WARN::hcd_init:473: FIQ at 0xc0364444
[ 1.898144] WARN::hcd_init:474: FIQ ASM at 0xc0364858 length 36
[ 1.905619] WARN::hcd_init:500: MPHI regs_base at 0xcc806000
[ 1.912706] dwc_otg bcm2708_usb: DWC OTG Controller
[ 1.919077] dwc_otg bcm2708_usb: new USB bus registered, assigned bus number 1
[ 1.927871] dwc_otg bcm2708_usb: irq 32, io mem 0x00000000
[ 1.934824] Init: Port Power? op_state=1
[ 1.940195] Init: Power Port (0)
[ 1.945208] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.953444] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.962110] usb usb1: Product: DWC OTG Controller
[ 1.968273] usb usb1: Manufacturer: Linux 3.12.26+ dwc_otg_hcd
[ 1.975559] usb usb1: SerialNumber: bcm2708_usb
[ 1.982360] hub 1-0:1.0: USB hub found
[ 1.987749] hub 1-0:1.0: 1 port detected
[ 1.993597] dwc_otg: FIQ enabled
[ 1.993619] dwc_otg: NAK holdoff enabled
[ 1.993630] dwc_otg: FIQ split-transaction FSM enabled
[ 1.993651] Module dwc_common_port init
[ 1.994095] usbcore: registered new interface driver usb-storage
[ 2.002051] mousedev: PS/2 mouse device common for all mice
[ 2.009897] bcm2835-cpufreq: min=700000 max=700000 cur=700000
[ 2.017300] bcm2835-cpufreq: switching to governor powersave
[ 2.024381] bcm2835-cpufreq: switching to governor powersave
[ 2.031540] sdhci: Secure Digital Host Controller Interface driver
[ 2.039195] sdhci: Copyright(c) Pierre Ossman
[ 2.045037] sdhci: Enable low-latency mode
[ 2.095127] mmc0: SDHCI controller on BCM2708_Arasan [platform] using platform's DMA
[ 2.106082] mmc0: BCM2708 SDHC host at 0x20300000 DMA 2 IRQ 77
[ 2.113563] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.120910] ledtrig-cpu: registered to indicate activity on CPUs
[ 2.130691] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.145282] usbcore: registered new interface driver usbhid
[ 2.152351] usbhid: USB HID core driver
[ 2.158328] TCP: cubic registered
[ 2.165238] Initializing XFRM netlink socket
[ 2.173108] NET: Registered protocol family 17
[ 2.181311] Key type dns_resolver registered
[ 2.189380] Indeed it is in host mode hprt0 = 00021501
[ 2.203825] registered taskstats version 1
[ 2.225795] Waiting for root device /dev/mmcblk0p2...
[ 2.245308] mmc0: new high speed SDHC card at address 0001
[ 2.265376] mmcblk0: mmc0:0001 00000 3.73 GiB
[ 2.273228] mmcblk0: p1 p2
[ 2.380992] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 2.392228] VFS: Mounted root (ext4 filesystem) on device 179:2.
[ 2.401373] devtmpfs: mounted
[ 2.406495] Freeing unused kernel memory: 144K (c060e000 - c0632000)
[ 2.415272] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 2.424932] Indeed it is in host mode hprt0 = 00001101
[ 2.635576] usb 1-1: New USB device found, idVendor=0424, idProduct=9512
[ 2.645506] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.657486] hub 1-1:1.0: USB hub found
[ 2.663049] hub 1-1:1.0: 3 ports detected
[ 2.945327] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 3.055749] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 3.064260] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.085383] smsc95xx v1.0.4
[ 3.160245] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-bcm2708_usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:df:59:18
[ 4.067899] udevd[156]: starting version 175
[ 5.165036] Adafruit Industries' Raspberry Pi PWM driver v1.0
[ 6.298758] bcm2708-i2s bcm2708-i2s.0: Failed to create debugfs directory
[ 11.125637] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 11.641466] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 12.467512] bcm2708_spi bcm2708_spi.0: master is unqueued, this is deprecated
[ 12.492121] bcm2708_spi bcm2708_spi.0: SPI Controller at 0x20204000 (irq 80)
[ 12.682346] fbtft_device: SPI devices registered:
[ 12.691200] fbtft_device: spidev spi0.0 500kHz 8 bits mode=0x00
[ 12.699446] fbtft_device: spidev spi0.1 500kHz 8 bits mode=0x00
[ 12.707584] fbtft_device: 'fb' Platform devices registered:
[ 12.714865] fbtft_device: bcm2708_fb id=-1 pdata? no
[ 12.721930] fbtft_device: I2C devices registered:
[ 12.805125] fbtft_device: Deleting spi0.1 (spi0.1)
[ 12.818090] stmpe-spi spi0.1: stmpe610 detected, chip id: 0x811
[ 12.842867] fbtft_device: Deleting spi0.0 (spi0.0)
[ 12.855765] fbtft_device: GPIOS used by 'adafruitrt35':
[ 12.862733] fbtft_device: 'dc' = GPIO25
[ 12.885356] fbtft_device: SPI devices registered:
[ 12.891763] fbtft_device: stmpe610 spi0.1 500kHz 8 bits mode=0x00
[ 12.915261] fbtft_device: fb_hx8357d spi0.0 32000kHz 8 bits mode=0x00
[ 13.007499] input: stmpe-ts as /devices/platform/bcm2708_spi.0/spi_master/spi0/spi0.1/stmpe-ts.0/input/input0
[ 14.966797] graphics fb1: fb_hx8357d frame buffer, 480x320, 300 KiB video memory, 4 KiB DMA buffer memory, fps=20, spi0.0 at 32 MHz
[ 20.186506] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 23.853113] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 25.449015] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xCDE1
[ 31.641366] Adding 102396k swap on /var/swap. Priority:-1 extents:2 across:2134012k SSFS
[ 33.112574] bcm2708_fb_blank blank_mode=1
[ 33.114009] bcm2708_fb_blank returns=1 p[1]=0x80000000
[ 34.524456] bcm2708_fb_blank blank_mode=0
[ 34.532711] bcm2708_fb_blank returns=0 p[1]=0x80000000
pi@raspberrypi ~ $
- googly_eyes
So it is looking like there might be a bad batch of these - there are 3 posts just like or similar to mine in the last day.
I tried the suggestion here: https://learn.adafruit.com/adafruit-pit ... s-on-pitft
But all I got was the same white screen.
I think this may warrant an RMA...
Is there a way to get one that has been tested prior to shipping?
- adafruit2
hey googly, it looks like the side tabs ont he flex TFT connector are loose, can you push them in all the way and try again?googly_eyes wrote:
- googly_eyes
OK, that did it... thank your for the help.
crisis averted...
crisis averted...
Wow - good eyes. I can barely see that
