I first used the "any pin" setup (using an uno), and the whole strip just flashed like crazy without any pattern at all. So, I tried the SPI setup instead (with clock on 13 and data on 11), and I had a bit more luck. The set of lights runs the length of the strip, changing color like it should with each run, but the other lights on the strip, that shouldn't be on at all, are flashing on and off seemingly at random.
Code below. Trippy video here (Alternate video source). Any idea what's going wrong?
// Simple strand test for Adafruit Dot Star RGB LED strip.
// This is a basic diagnostic tool, NOT a graphics demo...helps confirm
// correct wiring and tests each pixel's ability to display red, green
// and blue and to forward data down the line. By limiting the number
// and color of LEDs, it's reasonably safe to power a couple meters off
// the Arduino's 5V pin. DON'T try that with other code!
#include <Adafruit_DotStar.h>
// Because conditional #includes don't work w/Arduino sketches...
#include <SPI.h> // COMMENT OUT THIS LINE FOR GEMMA OR TRINKET
//#include <avr/power.h> // ENABLE THIS LINE FOR GEMMA OR TRINKET
#define NUMPIXELS 240 // Number of LEDs in strip
// Here's how to control the LEDs from any two pins:
#define DATAPIN 5
#define CLOCKPIN 4
//Adafruit_DotStar strip = Adafruit_DotStar(NUMPIXELS, DATAPIN, CLOCKPIN);
// Hardware SPI is a little faster, but must be wired to specific pins
// (Arduino Uno = pin 11 for data, 13 for clock, other boards are different).
Adafruit_DotStar strip = Adafruit_DotStar(NUMPIXELS);
#if defined(__AVR_ATtiny85__) && (F_CPU == 16000000L)
clock_prescale_set(clock_div_1); // Enable 16 MHz on Trinket
#endif
strip.begin(); // Initialize pins for output
strip.show(); // Turn all LEDs off ASAP
// Runs 10 LEDs at a time along strip, cycling through red, green and blue.
// This requires about 200 mA for all the 'on' pixels + 1 mA per 'off' pixel.
int head = 0, tail = -10; // Index of first 'on' and 'off' pixels
uint32_t color = 0xFF0000; // 'On' color (starts red)
strip.setPixelColor(head, color); // 'On' pixel at head
strip.setPixelColor(tail, 0); // 'Off' pixel at tail
strip.show(); // Refresh strip
delay(10); // Pause 20 milliseconds (~50 FPS)
if (++head >= NUMPIXELS) { // Increment head index. Off end of strip?
head = 0; // Yes, reset head index to start
if ((color >>= 8) == 0) // Next color (R->G->B) ... past blue now?
color = 0xFF0000; // Yes, reset to red
if (++tail >= NUMPIXELS) tail = 0; // Increment, reset tail index
