Hi, I'm trying to combine two projects on to the Pro-Trinket 5v; one of the project is a 7-segment LED clock on a backpack and the other is a BMP180 barometer on an RGBLCD display. Are the two libraries (Adafruit_LEDBackpack.h and Adafruit_RGBLCDShield.h) compatible to be used in the same sketch to allow the hardware share the same SDA & SCL, A4/A5 pins, on the ProTrinket?
I am asking because when I do that the clock and the LED runs but the RGBLCD unit displays only all bright blocks & I can't tell if the BMP180 is even working; but each project will run fine independently on their own sketch on the ProTrinket of course.
Just wondering if I need to somehow separate or isolate the SDA/SCL connections by address or something when they are in the same sketch and sharing the same A4/A5 pins. I'm hoping I don't have to but please let me know.
Thank you.
RGBLCDShield & LEDBackpack.h's...
- Franklin97355
Re: RGBLCDShield & LEDBackpack.h's...
i2c devices need to have unique addresses but, in most cases can share the pins. If you post your code we can have a look and see if there is a way to make it work. Please use the </> button and paste your code between the
tags.
