But I can't get the buttons to do anything. What am I missing?
I understand the 3rd button is gpio #23 and pin 16. What are the gpio numbers for each of the 4 buttons?
This code is running but nothing is happening:
# Import the modules to send commands to the system and access GPIO pins
from subprocess import call
import RPi.GPIO as gpio
# Define a function to keep script running
def loop():
input()
# Define a function to run when an interrupt is called
def shutdown(pin):
call('halt', shell=False)
gpio.setmode(gpio.BOARD) # Set pin numbering to board numbering
gpio.setup(16, gpio.IN) # Set up pin as an input
gpio.add_event_detect(16, gpio.RISING, callback=shutdown, bouncetime=200) # Set up an interrupt to look for button presses
loop() # Run the loop function to keep script running
#include <bcm2835.h>
#include <stdio.h>
#include <stdlib.h>
#include <getopt.h>
#include <string.h>
#define DEFAULT_PIN RPI_GPIO_P1_16
static const int DEFAULT_TIME = 1000;
static const int DEFAULT_FREQ = 25;
static const char* DEFAULT_COMMAND = "/sbin/poweroff";
int main(int argc, char **argv)
int count = 0;
int wait_time = DEFAULT_TIME;
int poll_freq = DEFAULT_FREQ;
int pin = DEFAULT_PIN;
int invert = 0;
int pud_mode = -1;
int verbose = 0;
const char* command = DEFAULT_COMMAND;
while (1) {
int option_index = 0;
int c;
static struct option long_options[] = {
{ "time", required_argument, 0, 't' },
{ "freq", required_argument, 0, 'f' },
{ "command", required_argument, 0, 'c' },
{ "pull", required_argument, 0, 'p' },
{ "gpio", required_argument, 0, 'g' },
{ "invert", no_argument, 0, 'i' },
{ "verbose", no_argument, 0, 'v' },
{ "help", no_argument, 0, 'h' },
{ 0, 0, 0, 0 }
c = getopt_long(argc, argv, "t:f:c:g:p:ivh?", long_options, &option_index);
if (c == -1) break;
switch (c) {
case 't':
wait_time = atoi(optarg);
break;
case 'f':
poll_freq = atoi(optarg);
break;
case 'c':
command = strdup(optarg);
break;
case 'g':
pin = atoi(optarg);
break;
case 'p':
if (optarg[0] == 'u')
pud_mode = BCM2835_GPIO_PUD_UP;
else if (optarg[0] == 'd')
pud_mode = BCM2835_GPIO_PUD_DOWN;
else if (optarg[0] == 'o')
pud_mode = BCM2835_GPIO_PUD_OFF;
else {
fprintf(stderr, "Invalid pull mode '%s'. Can be one of 'up', 'down' or 'off'.\n", optarg);
exit(1);
break;
case 'i':
invert = 1;
break;
case 'v':
verbose = 1;
break;
case '?':
case 'h':
printf("Usage: raspi-off-button [OPTIONS]\n");
printf(" -t, --time Time the input must be active (milliseconds, default %d)\n", DEFAULT_TIME);
printf(" -f, --freq Polling frequency (milliseconds, default %d)\n", DEFAULT_FREQ);
printf(" -c, --command Command to run (default \"%s\")\n", DEFAULT_COMMAND);
printf(" -g, --gpio GPIO number (default %d)\n", DEFAULT_PIN);
printf(" -i, --invert Invert input, i.e. pull up and wait for it to go low\n");
printf(" -p, --pull Pull up/down mode ('up', 'down', 'off', default is 'down' or 'up' if invert is enabled)\n");
printf(" -v, --verbose Verbose output\n");
return EXIT_SUCCESS;
default:
fprintf(stderr, "Unhandled option: %c\n", c);
return EXIT_FAILURE;
if (pud_mode == -1) {
if (invert)
else
if (verbose) printf("Defaulting pull mode to %u (%s)\n", pud_mode, (pud_mode == BCM2835_GPIO_PUD_UP) ? "up" : "down");
if (wait_time < 0) {
fprintf(stderr, "Invalid value for time option: %d\n", wait_time);
if (poll_freq < 0) {
fprintf(stderr, "Invalid value for freq option: %d\n", poll_freq);
if (pin < 0 || pin > 255) {
fprintf(stderr, "Invalid value for GPIO pin: %d\n", pin);
if (!bcm2835_init())
return 1;
if (verbose) printf("Setting pin %d to input mode\n", pin);
bcm2835_gpio_fsel(pin, BCM2835_GPIO_FSEL_INPT);
if (verbose) printf("Setting pin %d pull mode to %d\n", pin, pud_mode);
bcm2835_gpio_set_pud(pin, pud_mode);
while (1)
uint8_t value = bcm2835_gpio_lev(pin);
value ^= invert;
if (value) count += poll_freq; else count = 0;
if (value & verbose) printf("Pin %d is active\n", pin);
if (count >= wait_time) {
if (verbose) printf("Pin was active %d, running %s\n", count, command);
system(command);
break;
delay(poll_freq);
bcm2835_close();
return 0;
