I am trying to design a simple part that will attach to the resistive touch screen, but the product page doesn't provide a spec sheet with the exact dimensions.
I don't want to have the part block some of the touch-sensitive area, but the part needs to partially overlay the touch screen.
It will act sortof like a frame while protecting the 4-wire cable.
Need Spec Sheet for 7" Resistive Touch Screen Overlay
- novasharper
- Franklin97355
Re: Need Spec Sheet for 7" Resistive Touch Screen Overlay
From the product page:
TECHNICAL DETAILS
Outer Dimensions: 165mm x 105mm / 6.5" x 4"
Inner Dimensions: 151mm x 91mm - make sure your screen visible area is equal or smaller than this number!
Weight: 55 g
- novasharper
Yes, I saw that, but are the inner dimensions centered? If they are off center, what are the offsets on the sides? What is the height of the overlay? Where is the 4-wire connector located on one side?
