We are planning on mounting the 5" backpack on a new project. The website shows the location of the 4 mounting holes, but not the diameter. I would like to match the diameter on our main board so we can use the same screws on both ends of the stand-offs. If you could supply the diameter or a pointer to the info I would be able to finalize the PCB layout constraints.
Thank you.
5" backpack mechanical question
Re: 5" backpack mechanical question
added dims to the product page: https://www.adafruit.com/products/2232
Mounting Hole Distance: 115mm x 86mm / 4.5" x 3.4"
Mounting Hole Diameter: 2.8mm / 0.11"
- ahamilton
Perfect. Thanks!
