colorwheel_progmem_32x32:33: error: 'A0' was not declared in this scope
colorwheel_progmem_32x32:33: error: 'A1' was not declared in this scope
colorwheel_progmem_32x32:33: error: 'A2' was not declared in this scope
colorwheel_progmem_32x32:33: error: 'A3' was not declared in this scope
Here is the test code that I downloaded from GitHub
// colorwheel_progmem demo for Adafruit RGBmatrixPanel library.
// Renders a nice circle of hues on our 32x32 RGB LED matrix:
// http://www.adafruit.com/products/607
// This version uses precomputed image data stored in PROGMEM
// rather than calculating each pixel. Nearly instantaneous! Woo!
// Written by Limor Fried/Ladyada & Phil Burgess/PaintYourDragon
// for Adafruit Industries.
// BSD license, all text above must be included in any redistribution.
#include <Adafruit_GFX.h> // Core graphics library
#include <RGBmatrixPanel.h> // Hardware-specific library
#include "image.h"
// If your 32x32 matrix has the SINGLE HEADER input,
// use this pinout:
#define CLK 8 // MUST be on PORTB! (Use pin 11 on Mega)
#define OE 9
#define LAT 10
#define A A0
#define B A1
#define C A2
#define D A3
// If your matrix has the DOUBLE HEADER input, use:
//#define CLK 8 // MUST be on PORTB! (Use pin 11 on Mega)
//#define LAT 9
//#define OE 10
//#define A A3
//#define B A2
//#define C A1
//#define D A0
RGBmatrixPanel matrix(A, B, C, D, CLK, LAT, OE, false);
int i, len;
uint8_t *ptr = matrix.backBuffer(); // Get address of matrix data
// Copy image from PROGMEM to matrix buffer:
memcpy_P(ptr, img, sizeof(img));
// Start up matrix AFTER data is copied. The RGBmatrixPanel
// interrupt code ties up about 40% of the CPU time, so starting
// it now allows the prior drawing code to run even faster!
matrix.begin();
// do nothing
