Sorry I realized my post the other day was incomplete.
In the past I have purchased a switch with these minimal specs (The other guys specs.)
I want to now buy for Adafruit. Can you tell with this bit of info if it will be ok.
I just need a simple on/off latching.
Most notably I see the LED lamp is 6V as compared to 110V that kinda seems big to me.
Sorry I am just the buyer not the engineer.
ANY/ALL input is appreciated. TIA
Illuminated Metal Push Button Switch 110V AC 16mm
Operation Current Rating: 3A
Led voltage: 110V AC
Operation type: Latching
Ada's specs
Switch rating: 3A / 250VDC
Switch contacts: 1 NO, 1 NC
Material: Chrome-plated brass
Grade: IP40/IP67
Contact resistance: < 50 mOhm
Insulation resistance: > 1000 Mohm
Temperature: -20 C to +55 C
Mechanical life: > 500,000
Electrical life: > 50,000
Panel thickness: 1-13mm
Operating pressure: 1.5 - 2.5 N
Operating stroke: 2mm
Lamp rated voltage: 6V
Help please > Led Illuminated switch spec ?? (edited post)
- jans7890
- adafruit_support_bill
Re: Help please > Led Illuminated switch spec ?? (edited pos
.What is the voltage and current you need to switch?
What voltage is available for the LED?
If all you have is 110v AC, then the other switch is a better choice.
