128x32 OLED IC2 display not working
- Lesbardots
I have wired up the 128x32 OLED IC2 display as per the tutorial and loaded the example program (ssd1306_128x32_i2c), changed the .h file for the correct display and nothing. No sign of life. Any ideas on what I can try? Program is running OK based on the serial output.
- Attachments
- wiring_uno.jpg (332.85 KiB) Viewed 330 times
- wiring_oled.jpg (182.33 KiB) Viewed 330 times
- adafruit_support_rick
Re: 128x32 OLED IC2 display not working
Very strange. Can you try some different jumper wires and a different location of the breadboard?
- Lesbardots
Thanks for the response. I did move it and it started working with the Uno. I really want to use it with the Trinket Pro and so far have been unable to get it working but that's another post. Many thanks for the help.
Wiring for the Trinket Pro should be identical to the Uno. Code should also be the same.
