I'm currently trying to get Raspberry Pi (Rev1 B) to control Adafruit 36mm Square RGB Pixels (WS2801). https://www.adafruit.com/products/683
I have the Adafruit WebIDE installed and running.
The Adafruit_LEDPixels.py example seams to work, however there a bit of random flickering doing on.
My question is how do you set all the pixels to a given colour?
The tutorial at https://learn.adafruit.com/36mm-led-pixels/code only gives code for the arduino.
Has anyone got an examples of how you can control them using python?
Raspberry Pi with 36mm Square RGB Pixels (WS2801)
- MrStone
- adafruit_support_rick
Re: Raspberry Pi with 36mm Square RGB Pixels (WS2801)
MrStone wrote:My question is how do you set all the pixels to a given colour?
for i in range(len(pixels)):
setpixelcolor(pixels, i, Color(r, g, b))
writestrip(pixels)
- MrStone
Hi Rick,
Thanks for your reply.
I'm not that good with python code, I put the code below together but nothing happens.
What am I doing wrong? Please help!
#!/usr/bin/env python
# Test code for Adafruit LED Pixels, uses hardware SPI
import RPi.GPIO as GPIO, time
DEBUG = 1
GPIO.setmode(GPIO.BCM)
def slowspiwrite(clockpin, datapin, byteout):
GPIO.setup(clockpin, GPIO.OUT)
GPIO.setup(datapin, GPIO.OUT)
for i in range(8):
if (byteout & 0x80):
GPIO.output(datapin, True)
else:
GPIO.output(clockpin, False)
byteout <<= 1
GPIO.output(clockpin, True)
SPICLK = 23
SPIDO = 19
ledpixels = [0] * 25
def writestrip(pixels):
spidev = file("/dev/spidev0.0", "w")
spidev.write(chr((pixels[i]>>16) & 0xFF))
spidev.write(chr((pixels[i]>>8) & 0xFF))
spidev.write(chr(pixels[i] & 0xFF))
spidev.close()
time.sleep(0.002)
def Color(r, g, b):
return ((r & 0xFF) << 16) | ((g & 0xFF) << 8) | (b & 0xFF)
def setpixelcolor(pixels, n, r, g, b):
if (n >= len(pixels)):
return
pixels[n] = Color(r,g,b)
def setpixelcolor(pixels, n, c):
return
pixels[n] = c
def colorwipe(pixels, c, delay):
setpixelcolor(pixels, i, c)
writestrip(pixels)
time.sleep(delay)
while True:
setpixelcolor(pixels, i, Color(50, 50, 0))
while True:
for i in range(len(ledpixels)):
setpixelcolor(ledpixels, i, Color(50, 50, 0))
writestrip(ledpixels)
time.sleep(1)
