Adafruit Flora RGB Smart Pixel
This is a special forum devoted to educators using Adafruit and Arduino products for teaching.
Postby katehartman » Sat Dec 08, 2012 11:56 am
I'm trying to create an extremely bare bones example with a single pixel, based off of "floratest". However I'm finding red & green are swapped. Rather than lighting RED, GREEN, BLUE, the pixels lights GREEN, RED, BLUE with the code below. Anyone else having this problem?
#include "Adafruit_FloraPixel.h"
Adafruit_FloraPixel strip = Adafruit_FloraPixel(1);
  strip.begin();
  strip.show();
  strip.setPixelColor(0, Color(255, 0, 0));
  strip.show();
  delay(500);
  strip.setPixelColor(0, Color(0, 255, 0));
  strip.show();
  delay(500);
  strip.setPixelColor(0, Color(0, 0, 255));
  strip.show();
  delay(500);
  strip.setPixelColor(0, Color(0, 0, 0));
  strip.show();
  delay(1000);
RGBPixel Color(byte r, byte g, byte b)
  RGBPixel p;
  p.red = r;
  p.green = g;
  p.blue = b;
  return p;
katehartman
Re: Adafruit Flora RGB Smart Pixel
Postby bekathwia » Sun Dec 09, 2012 1:58 pm
Hey Kate,
You (and I) received an early batch of smart pixels, which were made with GRB LEDs, not RGB LEDs. They'll work fine (with two color channels reversed in your code) so long as they're not combined in the same chain with RGB pixels. Lucky you, limited edition! :D
None of the production starter packs or pixels will have this issue, we made sure! If you need more GRB pixels for a project, though, let me know.
bekathwia
Postby katehartman » Sun Dec 09, 2012 11:00 pm
Ah, good to know. Thanks!
katehartman
Return to For Educators
New Products [107]
More Dev Boards[31]
Components & Parts[70]
LEDs[111]
Cables[62]
