Recently, we have purchased multiple components from you to make educational kits. We have given those to students and the kits are working fine. Now, we want to make a mounting boards to mount all the components for a semi permanent installations. Most of the boards have two or more mounting holes but I could not find the drawings showing their exact location. Can you please provide me the drawings of the following breakout boards. I need overall size, mounting board and header location with respect to a common reference.
1) USB XBee Adapter (#247)
2) BMP085 Pressure/Temperature/Altitude Sensor (#391)
3) ADS1015 12-Bit ADC (#1083)
4) Triple-axis Accelerometer+Magnetometer (#1120)
5) USB / DC / Solar Lithium Ion/Polymer charger (#390)
6) INA219 High Side DC Current Sensor (#904)
7) L3GD20 Triple-Axis Gyro Breakout (#1032)
Mechanical Drawings Needed
Re: Mechanical Drawings Needed
We publish our board files in Eagle format (EagleCAD is a free download). You should find links to the board files under the "Downloads" tab on the product description page.
- kunalpatankar
Only battery charger has schematics and PCB design files under "Download" tab. I need mounting hole locations of all the sensors, otherwise I will have to measure the dimensions which is tricky and may be inaccurate.
Looks like some of them are in the downloads sections of the tutorials. I'll see if I can find the rest.
http://www.ladyada.net/make/xbee/download.html
http://learn.adafruit.com/adafruit-4-ch ... /downloads
http://learn.adafruit.com/lsm303-accele ... /downloads
http://learn.adafruit.com/adafruit-ina2 ... /downloads
we have our board files on github these days, you can search the adafruit account for files
https://github.com/adafruit/ADS1X15-Breakout-Board-PCBs
https://github.com/adafruit/Adafruit-An ... eters-PCBs
https://github.com/adafruit/Adafruit-IN ... Sensor-PCB
etc
thanks!
etc
thanks!
- kunalpatankar
Thanks a ton!
